Mathcad Toolbox
Mathcad Toolbox - Contains analogs of functions from Mathcad - Messages
#81 Posted: 2018/12/6 05:36:46
1,554 likes in 1,864 posts.
Updated. Now you can also use simple form for D() function definition.
4 users liked this post
sergio 2018/12/6 06:45:00, frapuano 2018/12/6 06:58:00, Radovan Omorjan 2018/12/6 09:33:00, Alvaro 2018/12/6 10:09:00
#82 Posted: 2018/12/6 06:01:27
But x in D(t,x) is vector.
#83 Posted: 2018/12/24 05:33:39
Updated.
Now x in simple D(t,x) definition must be a scalar.
2018-12-24_13-43-45.png iode.test1.png iode.test2.png 2018-12-24_13-32-46.png
iode.examples.sm (204.21 KiB) downloaded 2102 time(s).
iode.kinetic1.sm (7.75 KiB) downloaded 2038 time(s).
iode.kinetic2.sm (14.4 KiB) downloaded 1908 time(s).
iode.kinetic3.sm (14.08 KiB) downloaded 6846 time(s).
iode.integrate.sm (10.57 KiB) downloaded 6824 time(s).
iode.test1.sm (22.49 KiB) downloaded 1889 time(s).
iode.test2.sm (22.5 KiB) downloaded 2023 time(s).
iode.Amplitude detector.sm (20.18 KiB) downloaded 1978 time(s).
iode.examples.pdf (416.34 KiB) downloaded 1145 time(s).
iode.kinetic1.pdf (74.06 KiB) downloaded 981 time(s).
iode.kinetic2.pdf (90.4 KiB) downloaded 963 time(s).
iode.kinetic3.pdf (88.45 KiB) downloaded 968 time(s).
iode.integrate.pdf (88.91 KiB) downloaded 1062 time(s).
iode.test1.pdf (116.24 KiB) downloaded 1027 time(s).
iode.test2.pdf (121.64 KiB) downloaded 957 time(s).
iode.Amplitude detector.pdf (147.71 KiB) downloaded 1051 time(s).
sergio 2018/12/24 06:25:00, NDTM Amarasekera 2018/12/24 09:43:00, frapuano 2018/12/24 14:23:00, Radovan Omorjan 2018/12/24 14:51:00
#84 Posted: 2019/1/16 06:05:17
Updated. Rkadapt() fixed.
sergio 2019/1/16 06:31:00, NDTM Amarasekera 2019/1/16 07:32:00, frapuano 2019/1/16 06:25:00
#85 Posted: 2019/1/31 17:43:52
Updated ( >= SMath Studio 0.99.6970).
Changes:
- divided into two plugins (the second one is Intel ODE Solver Library);
- version changed (0.2.x.x);
- refactored.
#86 Posted: 2019/2/11 09:36:21
Some news.
It's hard but I want to realize a general solution for some types of tasks. Specially for this I need more powerful symbolic engine inside SMath. Therefore I made symcs project. I hope that we can use this solution in other similar cases.
That's why I split the plugin.
frapuano 2019/2/11 13:49:00, Radovan Omorjan 2019/2/11 10:58:00
#87 Posted: 2019/2/11 11:01:58
I think that most of the Mathcad users know what you intend to do and I really appreciate that
#88 Posted: 2019/2/11 15:52:40
Viacheslav is an ancient Mathsoft visitor.
I still have a document from Him ... 2D Implicit plot.
Is possible to code 1/1 Mathcad Given/ODEsolve ?
#89 Posted: 2019/2/11 16:35:16
No, Jean, 1/1 - not possible. Now they have two different realisations: MC11-MC15 and Prime. But I can do something similar. Plugin can implicity collect information about available ode solvers and you can choose them in the context menu.
frapuano 2019/2/12 06:00:00
#90 Posted: 2019/2/11 16:52:19
I can see you "busy" ! Gorgeous context menu.
What is that Smath Community doing: Building Cathedrals/Pyramids ?
You mean: Mathcad Prime "cluster fuck" in US appreciation from Collab.
#91 Posted: 2021/7/11 00:23:42
1,123 likes in 1,795 posts.
Some news.
Hi uni. It is possible to enable a clone of that component for return only the expressions inside? For example, the set of the equations
Also, it is possible too to add the option for mark with a round box the area?
#92 Posted: 2021/7/11 01:20:49
Yes, it is possible.
Alvaro 2021/7/11 02:41:00
#93 Posted: 2021/11/26 00:11:56
Coming soon, but for now as an experiment.
Davide Carpi 2021/11/29 06:40:00, Alvaro 2021/11/26 04:23:00
#94 Posted: 2021/11/28 15:47:31
I have verified that linear interpolation is used, which is described in the manual.
I changed the interpolation method to linear and also changed the notation of the derivative by analogy ( "`" ).
#95 Posted: 2021/11/28 16:42:18
Prime symbol looks much better (′). I think it's better to use it.
#96 Posted: 2021/11/28 18:49:59
I was wrong. Linear interpolation and linear spline interpolation are different things. I will try to find the formulas that are used in these functions.
#97 Posted: 2021/11/29 02:43:07
A simple test that shows the interpolation method used by the ODE solver. Obviously, the lspline() function is used.
Odesolve() with rkfixed method (Mathcad 15).
Odesolve interpolation test.mcd.zip (8.84 KiB) downloaded 400 time(s).
The same for Mathcad Prime 7.0 (Adams method used).
#98 Posted: 2021/11/29 20:31:00
Ok, I found a bug in rkfixed() and finally figured out the difference between interpolation functions. In the picture below, I repeated part of the calculations from Mathcad. As you can see, to interpolate the numerical solution of the ODE, a cubic spline is used, linear at the end points.
Bugs will be fixed when the build server starts working.
Links:
1. Cubic spline
2. Cubic Spline Interpolation
Cubic spline interpolation using Mathcad (2009).pdf (256.71 KiB) downloaded 2529 time(s).
#99 Posted: 2021/11/29 21:30:48
Thanks Viacheslav ... superb demo.
BTW, I was wrong ODEsolve is lspline MCD 11.
Years ago, Tom G. had exposed the different deficiencies
wrt to each l_p_c cubic spline ... Matlab as well.
So, your next headache is to figure the best solver from
the huge Smath library [17], Mathcad stiff is Radau MCD 2001i, 11.
#100 Posted: 2021/11/30 01:28:14
598 likes in 1,380 posts.
This day should be accepted as a milestone. We have to celebrate this day annually.
There should be carnivals, fireworks should enlighten the night.
