Matlab Runtime Library
Matlab Runtime Library - Consists of approximately 400 Matlab math functions - Messaggi
#1 Pubblicato: 18/08/2013 14:08:18
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
CorFlags will help you to use this plugin on 64-bit system. mw prefix means: Matlab Workspace or MathWorks.
Functions list (blue color - implemented):
General Purpose Commands
Mostra spoiler
Operators and Special Functions
Mostra spoiler
Elementary Matrices and Matrix Manipulation
Mostra spoiler
Elementary Math Functions
Mostra spoiler
Data Analysis and Fourier Transform Functions
Mostra spoiler
Polynomial and Interpolation Functions
Mostra spoiler
Function Functions and ODE Solvers
Mostra spoiler
Character String Functions
Mostra spoiler
File I/O Functions
Mostra spoiler
Data Types
Mostra spoiler
Time and Dates
Mostra spoiler
Examples:
MatlabCppMathLibrary. Example 3.png matlab.ode.test1.png matlab.ode.test2.png 2018-12-24_23-18-48.png
matlab.ode.kinetic1.sm (8,27 KiB) scaricato 2102 volta(e).
matlab.ode.kinetic2.sm (13,2 KiB) scaricato 1989 volta(e).
matlab.ode.kinetic3.sm (12,88 KiB) scaricato 1984 volta(e).
matlab.ode.test1.sm (19,22 KiB) scaricato 1992 volta(e).
matlab.ode.test2.sm (18,87 KiB) scaricato 2023 volta(e).
matlab.ode.Amplitude detector.sm (20,18 KiB) scaricato 2073 volta(e).
matlab.ode.kinetic1.pdf (77,95 KiB) scaricato 1187 volta(e).
matlab.ode.kinetic2.pdf (91,14 KiB) scaricato 1167 volta(e).
matlab.ode.kinetic3.pdf (87,77 KiB) scaricato 1100 volta(e).
matlab.ode.test1.pdf (110,56 KiB) scaricato 1215 volta(e).
matlab.ode.test2.pdf (110,97 KiB) scaricato 1090 volta(e).
matlab.ode.Amplitude detector.pdf (148,9 KiB) scaricato 1148 volta(e).
Matlab C++ Math Library. ODE solvers. Amplitude detector.sm (14,36 KiB) scaricato 2489 volta(e).
ioan92 20/08/2013 05:35:00, Davide Carpi 20/08/2013 17:47:00, Radovan Omorjan 19/08/2013 11:37:00
#2 Pubblicato: 18/08/2013 18:41:11
Gruppo: Moderator
Works for me. Does that imply that any matlab function could be used by SMath? Any chance for interactive plots? Ok, I know: Not so fast...
#3 Pubblicato: 18/08/2013 22:09:58
Gruppo: Moderator
Citazione
Chapter 25. MATLAB C/C++ Graphics Library 2.1 Release Notes
Using this library, in conjunction with the MATLAB Compiler and the MATLAB C/C++ Math Library, you can create stand-alone applications from M-files that use lines, text, meshes, and polygons as well as interactive visual interface components such as menus, push buttons, and dialog boxes.
Citazione
Note. You must use the MATLAB Compiler to create C or C++ stand-alone graphics applications. Calling MATLAB C/C++ Graphics Library routines directly from a C or C++ source module is not supported.
So, the answer is no.
Citazione
I added a list of the available functions (MATLAB C++ Math Library. Reference. Version 2.pdf). Most of them, I think, can be used. The library has functions to solve the ODE: ode45, ode23, ode113, ode15s, ode23s.
Radovan Omorjan 19/08/2013 11:37:00, Martin Kraska 19/08/2013 10:40:00
#4 Pubblicato: 19/08/2013 11:47:38
Gruppo: Moderator
It seems it works for me as well
By the way, I do not have Matlab installed, just followed the instructions and I could see and use the four mentioned function in SMath from the starting post (mw...). Not quite sure how this could be used without Matlab, but never mind - just wanted to try it on .
[EDIT] Did not understand what uni said about ODE: ode45, ode23, ode113, ode15s, ode23s ?
#5 Pubblicato: 19/08/2013 11:52:31
Gruppo: Moderator
That sounds good. However, I don't know if any of these solvers has advantages over what we already have in various plugins.
How about the function find or fscanf?
#6 Pubblicato: 20/08/2013 02:12:17
Gruppo: Moderator
Updated. mwfind(1) added.
Radovan, this Math Library was created precisely in order to use the Matlab without Matlab.
There is one big problem when using functions from the library. The function can have a different number and different type parameters. Furthermore, a different number of the output data. SMath Studio doesn't support such features. I asked Andrew to think about it.
ioan92 20/08/2013 05:43:00, Martin Kraska 20/08/2013 02:31:00, Radovan Omorjan 20/08/2013 03:58:00
#7 Pubblicato: 20/08/2013 02:54:08
Gruppo: Moderator
Very nice. The real fun with find() comes if you can have matrix valued operands and results in boolean expressions. As these cannot be matrix-valued in
SMath, we at least need the matrix sign function. Uni, could you please add this?
In order to find all elements in M less then a number a, you would write in Matlab:
[MATH]find(MNot really nice and comprehensible (the expression may well be wrong), but no loop required.
#8 Pubblicato: 20/08/2013 03:41:16
Gruppo: Moderator
For the output parameters, an option would be to use embedded assignment, just like in Davide's findroot function. This is very transparant and handy. You would have an optional argument, being a vector of name=key pairs, where name is a variable name and key is an result item key. Your example then would look like
[MATH lang=eng]mwfind(mat(1,2,0,3,2,2),mat(I≡Index1,J≡Index2,V≡Values,3,1))[/MATH]
Of course, there are open questions: What should the return value be? Are there side effects of embedded assignments in nested expressions?
For providing optional input arguments, this would be an option as well. That would look a bit Python-like.
#9 Pubblicato: 20/08/2013 04:08:47
Gruppo: Moderator
If I understood well all of this, these mw... functions will be introduced gradually into SMath, as soon as these and similar problems would be solved in SMath. Was I right about it?
#10 Pubblicato: 20/08/2013 06:35:25
Gruppo: Moderator
Updated. mwsign(1), mweq(2), mwge(2), mwgt(2), mwle(2), mwlt(2), mwneq(2) added.
Relational operations (Reference, p. 32).
Davide Carpi 20/08/2013 07:30:00, Radovan Omorjan 20/08/2013 07:23:00
#11 Pubblicato: 20/08/2013 07:30:29
Gruppo: Moderator
Thank you uni. It seems I was right
By the way, the second argument does not need to be a matrix. Scalar will do the job as well
#12 Pubblicato: 21/08/2013 01:00:30
Gruppo: Moderator
Updated. mwfprintf(4), mwfscanf(3), mwfscanf(4).
Citazione
Yes, but it's an undocumented feature. The function takes a matrix as a parameter.
Martin Kraska 21/08/2013 17:46:00, Radovan Omorjan 21/08/2013 05:40:00
#13 Pubblicato: 21/08/2013 06:53:30
Gruppo: Moderator
Updated. mwode45(5), mwode23(5), mwode113(5), mwode15s(5), mwode23s(5) added.
mwode45(5) - (init, x1, x2, intvls, D) solve non-stiff differential equations, medium order method.
mwode23(5) - (init, x1, x2, intvls, D) solve non-stiff differential equations, low order method.
mwode113(5) - (init, x1, x2, intvls, D) solve non-stiff differential equations, variable order method.
mwode15s(5) - (init, x1, x2, intvls, D) solve stiff differential equations and DAEs, variable order method.
mwode23s(5) - (init, x1, x2, intvls, D) solve stiff differential equations, low order method.
Matlab C++ Math Library. ODE solvers. Arenstorf orbit.pdf (99,13 KiB) scaricato 1353 volta(e).
Martin Kraska 21/08/2013 17:45:00, Radovan Omorjan 21/08/2013 08:11:00
#14 Pubblicato: 21/08/2013 16:52:44
Gruppo: Moderator
Citazione
Now it is documented, but perhaps not officially supported ;-) Is there any chance to overload the operators? Do they have internal functions that could be overwritten?
Also, thanks for the file ops. Writing of strings is not supported so far?
I fail to read the datafile even if I remove the first line with the column titles. Would be interesting to see what performance we get.
One remark to function naming: This is of course entirely in the souvereignity of the plugin creator. Still I would make some recommendations, driven by
the objective, to make an SMath document as much math-on-paper like as opposed to program code.
- I'd recommend to shift the information on the function's origin from name prefixes like dn_, al_, mw... towards the dynamic assistant help string, much like it is done for the efi-loaded libraries.
- If a function is first or best in providing some feature (which quite frequently happens in your plugins), then please give it an intuitive generic name, perhaps with capital first character in order to indicate it as plugin-based. Example: dn_LinAlgEigenvalues() could well be Eigenvalues().
- technical information on which function actually is doing the job, might be shifted to the description string.
Surely, this all is a matter of taste and perhaps it is quickest, not to waste time on naming strategies. Either way, I try to keep up with documenting.
#15 Pubblicato: 21/08/2013 23:44:50
Gruppo: Moderator
Updated. Now the installer is located within the plugin.
I'll remove all of the prefixes, when Andrey will support the functions with the different types of parameters.
In MATLAB all the parameters are of type matrix. Inside the plugin takes place an implicit conversion to a type of matrix if you use a scalar. Therefore, for example, for the function mwabs() the result is a vector (matrix). Special support for scalar parameters makes sense to do only when overloading will be realized.
Martin Kraska 22/08/2013 12:54:00
#16 Pubblicato: 22/08/2013 13:29:59
Gruppo: Moderator
Thank you for considering to rename functions. I also would not mind 1x1 matrix results to be converted to scalars by default, even if that might be mathematically a bit sloppy. But perhaps someone can give an example where that would be harmful...
#17 Pubblicato: 22/08/2013 13:46:39
Gruppo: Moderator
I would like to point the user to the environment variable editor using the command line
"C:\Windows\system32\rundll32" sysdm.cpl,EditEnvironmentVariables
in the plugin handbook page.
but I have no idea how that can be made a link target in the hyperlink region (due to the " signs in the link). Davide, any idea?
An alternative would be that the installer tests for the presence of dll and path entry and adds the entry if required.
#18 Pubblicato: 22/08/2013 17:03:14
Gruppo: Moderator
This require to use an overload of the function that I've used inside the hyperlink region; I need to think how to unlock the feature without compromising those already existing....
P.S. I'm not sure that this command works after windows XP
Martin Kraska 22/08/2013 17:33:00
#19 Pubblicato: 22/08/2013 17:31:34
Gruppo: Moderator
I am using Win7 and got the command line from the program manager after clicking through the system control hierarchy. Faster is to locate the dialog via search for "Umg", german for "env".
#20 Pubblicato: 23/08/2013 03:42:17
Gruppo: Moderator
There is an user interaction issue. After updating the plugin and re-starting smath,
the installer dialog pops up and offers installation. You are also informed that you do not need installation if you already have the runtime environment installed. In this case it is natural that the user chooses [Cancel]. Then, however, the dialog pops up every time you launch smath.
If you choose [Install] even if you know that nothing needs to be installed, then suddenly the installer gets aware of that and just finishes and no more messages appear on start-up.
