Matlab Runtime Library
Matlab Runtime Library - Consists of approximately 400 Matlab math functions - Messaggi
#41 Pubblicato: 22/02/2014 06:30:19
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Davide Carpi 22/02/2014 07:58:00, Igor Skarine 27/02/2014 10:59:00
#42 Pubblicato: 27/02/2014 13:54:13
Igor Skarine
Igor Skarine
14 apprezzamenti in 97 post.
Hi Uni,
For some reason, I always have the same error, using mwfprintf() function.
It looks the same on both 32-bit and 64-bit Windows.
Could you explain what is wrong here ?
#43 Pubblicato: 27/02/2014 17:45:27
Gruppo: Moderator
Hi Igor.
There is a log.txt in the plugin directory: \extensions\plugins\4c2faab1-4d93-4904-8d88-a4e21512d179\1.0.4987.26944\
If you look at the contents, you will see errors when working with functions.
In this case, we see a problem in converting the operation result. Probably something has changed in the SMath Studio and my examples stopped working correctly.
mwfprint() works fine, but you need to set the current folder or absolute path. The error occurs after running the function while trying to return the result of work in bytes.
I will try to fix the error, if I can. Now I don't have the latest source.
#44 Pubblicato: 17/03/2014 20:01:41
Gruppo: Moderator
#45 Pubblicato: 11/04/2014 14:55:34
Gruppo: Moderator
Hi Uni,
Updated. Try now (with SMathStudio_Desktop_0.97.5189_32bit.exe for 64-bit).
#46 Pubblicato: 11/04/2014 18:52:17
Ryan Freund
Ryan Freund
20 apprezzamenti in 339 post.
I'm curios to know -
There is a plugin for using Maxima and a plugin to use Matlab/C++, is there advantage to starting using one over another? I mean is one more/less powerful. Is one better with units or symbolic?
Thanks!
#47 Pubblicato: 12/04/2014 02:11:10
Gruppo: Moderator
Updated. mwfscanf() now working too. Relative path also works. Strings as parameters not supported for now.
Thanks!
You can get these plugins from the Extensions Manager (I don't know how it called in english). They are very different. Matlab C++ Math Library - just a numeric library, not symbolic. Full description you can get from the MATLAB C++ Math Library. User's Guide. Version 2.1.pdf. Also, no need to install Matlab.
#48 Pubblicato: 12/04/2014 05:34:42
Gruppo: Moderator
Advantages of the matlab lib plugin:
  • more functions
  • more uniform and consistent function interface
  • better documentation (you can use original matlab docs in the web )
  • easy installation (just download the plugin)
  • certainly more performant numerics (did not benchmark this)
Advantages of the Maxima plugin
  • symbolic math
  • units handling
  • safe legal status
  • graphics functions (matlab has better ones, but they are not exposed to SMath in the plugin)
#49 Pubblicato: 14/04/2014 11:08:55
Ryan Freund
Ryan Freund
Thank you Martin and Uni
#50 Pubblicato: 18/07/2014 05:32:40
Dr. Parnassus
Dr. Parnassus
0 apprezzamenti in 5 post.
Hi Uni,
I would use the svd-function from the matlab c++ Math Library.
But the function is not available.
Thanks and best regards
#51 Pubblicato: 18/07/2014 10:34:06
Gruppo: Moderator
The fact is that not all functions realized. Only blue ones with the mw prefix exist.
#52 Pubblicato: 27/07/2014 07:17:40
Gruppo: Moderator
Updated. svd() added, but I'm not shure about how it works (correctly or not).
#53 Pubblicato: 27/07/2014 08:38:32
Gruppo: Moderator
I think something is wrong here. U matrix has extra column and S matrix should bi diagonal.
#54 Pubblicato: 27/07/2014 08:55:26
Gruppo: Moderator
Matlab svd example. S - transposed (I don't know why).
#55 Pubblicato: 27/07/2014 09:15:38
Gruppo: Moderator
Updated. svd() fixed.
Radovan Omorjan 27/07/2014 09:26:00
#56 Pubblicato: 27/07/2014 09:28:48
Gruppo: Moderator
I see. Thank you uni. I thought on [U,S,V] = svd(X,0) only.
#57 Pubblicato: 30/07/2014 02:08:50
Dr. Parnassus
Dr. Parnassus
Thank`s uni! Now I can continue my work in smath.
I will close matlab at once :-) - best regards.
#58 Pubblicato: 30/07/2014 06:51:59
Gruppo: Moderator
By the way, there is Dot Numerics plugin - by uni
#59 Pubblicato: 26/09/2014 03:01:58
idushy
idushy
0 apprezzamenti in 18 post.
Что обозначает в заглавном посте зеленый и синий цвет функций. Зеленые smath не "видит". Как заставить его их увидеть? Спасибо.
#60 Pubblicato: 26/09/2014 08:23:01
Gruppo: Moderator
Синие с префиксом mw реализованы, остальные ещё нет (по запросу), поэтому они не видны.
