Matlab Runtime Library - Consists of approximately 400 Matlab math functions - Messaggi
27.04.2016 11:18:22 [INFO ] [Plugin.Initialize()] Is64Bit() = 64
27.04.2016 11:18:22 [ERROR] [Plugin.Initialize()] 64bit platform not supported.
27.04.2016 11:18:22 [INFO ] [Plugin.Initialize()] Successfully. 0 functions loaded.
See here.
How to get this 32-bit version:
CorFlags /32bit+ SMathStudio_Desktop.exe
Links:
1. CorFlags .
Your new version of the Matlab C++ Library doesn't work. All functions are not defined. CoreFlags doesn't help.
Everything is OK if I use 1.0.5321.34595. I use it in all of my worksheets, it is one of the most valuable plugins for reliable "vectorisation".
My OS is Win7-64.
Utilities Matrix Test [mwall].pdf (21,15 KiB) scaricato 875 volta(e).
log.txt (21,46 KiB) scaricato 1592 volta(e).
WroteHi Uni,
My OS is Win7-64.
I tested the plugin on my machine (Win7 x64, SMath Studio 0.98.5953.21871) and it works fine with the 32 bit flag.
Can anybody else confirm the problem?
Yesterday tonight, I tried it on my home computer (Win7-64 as well) with the same result.
If I change config.ini 1.0.5960.39961 -> 1.0.5321.34595, old plugin works fine.
My installation is not standard. I'm using Martin's portable distribution with Maxima, updated to the latest version of Smatsh and plugins.
It is very convenient for me and everything had been working until your latest update of the Mathlab C++ plugin.
Hope you find the issue soon.
Thanks,
Igor
__________________________________________
Wonderful enough you can revert back to your older version. If your 5321 is older than mine 5346,
[5346 April 2014 from recollection ?], it may be like 5346, i.e: an INSTALLED version. What it means
in my understanding is that the "Plugins Manager" makes the plugins code work. From what Andrey
replied to me, the newest versions [per say the many of the latest versions] would install themslves
just by downloading. From what you say it does NOT.
I can prove what I'm saying, how? My 5346 INSTALLED works fine, including the Matlab "mwxxxx" that
I have tested. I have an uninstalled 5346 ... both directories are 1/1 !!! The UNINSTALLED 5346 does
not have Matlab "mwxxxx" , why? because the Plugins Manager didn not code them to work.
5346 INSTALLED does not have "Levenberg-Marquardt" ... 5346 UNINSTALLED does have Levenberg-Marquardt.
About that one Levenberg-Marquardt, I have no idea how it works in Smath. I have no error but no result.
I tested to optimise parameters of a model function, not to avail.
In short: your latest 5960 is not installed. If you evaporate your older version and redownlod the latest
version , will that scrap your years project ? From what Andrey was saying the latest versions need not the
the MSI install ... download, bingo.
As is: XP Home SP3/Smath 5346 are compatible companions.
True: JoBlo story is not same as ArtSue story.
Cheers, Jean ... reported observation.
Don't confuse SS executables and community's plugins; what was explained by Andrey is about built-in stuff (executables, built-in extensions, registry keys); when the program is updated or uninstalled, community's extensions are kept where they are (%APPDATA%\SMath path). Igor just stated he has reverted the old plugin (you have to edit the config.ini file in the %APPDATA%\SMath\extensions\plugins\{PLUGIN_GUID} path, and setup the version of a previously downloaded plugin, the name of one of the folders contained in that path).
Levenberg-Marquardt is part of NonlinearSolvers plugin, syntax is described in the Martin's Activebook (available in the Extensions Manager, or in the SVN repository)
Examples and algorithm: LevenbergMarquardt_testing.sm (45,64 KiB) scaricato 1799 volta(e).
WroteI'm using Martin's portable distribution with Maxima, updated to the latest version of Smatsh and plugins.
This means that SMathstudio_desktop.exe is the latest or the original?
WroteThis means that SMathstudio_desktop.exe is the latest or the original?
Of course all executables, dlls and plugins are the latest.
When I update to later version, I override all files from portable distribution (for Mono), then apply fix for 32bits.
I like to have the same Smath everywhere including my USB-key
For a few years this method worked perfectly.
WroteHope you find the issue soon.
Try now. I deleted the changes partially.
1.0.5960.39961 and 1.0.5963.610 do not work.
1.0.5321.34595 works fine.
EDIT: And if you using portable version, please give me it too for testing.
Please use this Link for downloading.
I provided minimal Smath portable installation that demonstrates the issue.
Thanks for your support.
WroteHello Uni,
The error log contains the following line:
CitazioneCould not load file or assembly 'cppmathlib, Version=1.0.5961.19770, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail. (Exception from HRESULT: 0x800736B1)
This means that a dependent assembly can't load. This can happen when the necessary libraries are absent on the machine. I tried to rebuild the assembly, may be it will help. If not you can try to install "Microsoft Visual C++ 2008 Redistributable Package".
EDIT: I can't reproduce the problem, because I have only one machine where plugin works in any configuration.
Your new build of the plugin works fine.
ODE solvers:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
matlab.ode.kinetic1.sm (8,27 KiB) scaricato 2102 volta(e).
matlab.ode.kinetic2.sm (13,2 KiB) scaricato 1989 volta(e).
matlab.ode.kinetic3.sm (12,88 KiB) scaricato 1984 volta(e).
matlab.ode.test1.sm (19,22 KiB) scaricato 1992 volta(e).
matlab.ode.test2.sm (18,87 KiB) scaricato 2023 volta(e).
matlab.ode.Amplitude detector.sm (20,18 KiB) scaricato 2073 volta(e).
matlab.ode.kinetic1.pdf (77,95 KiB) scaricato 1187 volta(e).
matlab.ode.kinetic2.pdf (91,14 KiB) scaricato 1167 volta(e).
matlab.ode.kinetic3.pdf (87,77 KiB) scaricato 1100 volta(e).
matlab.ode.test1.pdf (110,56 KiB) scaricato 1215 volta(e).
matlab.ode.test2.pdf (110,97 KiB) scaricato 1091 volta(e).
matlab.ode.Amplitude detector.pdf (148,9 KiB) scaricato 1148 volta(e).
