plotG(data,char,size,clr)
plotG(data,char,size,clr) - plotG(data,char,size,clr) - Messages
#1 Posted: 2018/2/17 23:19:44
This refactored style is ~ 25 times faster than the very original.
The nested style does not ring a bell about specific use ?
Random_8 Fill Critical Region.sm (17.72 KiB) downloaded 1209 time(s).
frapuano 2018/2/18 06:21:00, Andrey Ivashov 2018/2/18 06:27:00
#2 Posted: 2018/2/18 15:53:06
Basile
Basile
8 likes in 172 posts.
Jean,
It does not work in 6622.
In Graph: (does not display any graph)
Error: Random()= Function is not defined.
Thanks,
Basile
#3 Posted: 2018/2/18 16:32:39
2,340 likes in 4,041 posts.
Hello [USERLINK]Basile[/USERLINK].
It does work on my copy of 0.99.6622:
Tried different locales - everything seems ok.
Random(..) function is from Statistical Tools plug-in. Please check if this plug-in available on your PC.
#4 Posted: 2018/2/18 16:49:32
Basile
Basile
SMath-01.PNGHello Andrey,
Attached please find a print screen.
Am I doing something wreong?
Thank you,
Basile
#5 Posted: 2018/2/18 16:50:32
#6 Posted: 2018/2/18 17:05:33
Basile
Basile
SMath-02.PNGIt looks that it is...
#7 Posted: 2018/2/18 17:21:15
Please could you check what plug-in handles Random function in your case?
Also please try to test Random function... will it work in most usual scenarios on your environment?
#8 Posted: 2018/2/18 18:45:09
Basile
Basile
SMath-03.PNGHere it is...
And how do you want me to test the Rand, please?
#9 Posted: 2018/2/18 22:10:38
Am I doing something wrong?
Maybe YES, maybe NO ... maybe an undetected bug wrt your version,
though Andrey said/proved it works. If you visit "Samples", you
will find a huge "Random Utilities" [not more than a month old].
Cheers Basile, Jean
Basile Random.sm (8.17 KiB) downloaded 1100 time(s).
#10 Posted: 2018/2/19 09:52:38
Basile
Basile
SMath-04.PNGJean,
I run your and I get:
Basile
#11 Posted: 2018/2/19 11:54:45
Jean,
Basile
Sorry mon ami, the "Grand Doctors" is the next step.
"Random(,) not defined" does not mean error from the plugin,
rather it means the program does not recognize from incompatible code.
#12 Posted: 2018/2/19 14:46:31
Not sure, but may be this is because of sort order of plug-ins or some additional plug-in which breaks the logic...
Please could you execute the following in command line? (path to SMathStudio_Desktop.exe may differ on your PC)
"C:\Program Files (x86)\SMath Studio\SMathStudio_Desktop.exe" -silent -info
I would like to see the output of this command in order to try to reproduce this on my environment.
Davide Carpi 2018/2/19 20:37:00
#13 Posted: 2018/2/19 22:09:18
Basile
Basile
SMath-05.PNGHere it is:
#14 Posted: 2018/2/19 22:11:22
Basile
Basile
#15 Posted: 2018/2/21 03:59:05
Thank you very much! Now I have everything to try reproducing this issue.
