The value went beyond the maximum allowed positive number
The value went beyond the maximum allowed positive number - the value went beyond the maximum allowed positive number, error in the solve function - Messages
#1 Posted: 2020/2/12 10:38:12
Joki720
Joki720
0 likes in 12 posts.
Who has faced such a problem, how can it be solved?
Project from below
Poverochnyjj raschjot ehzhektora.sm (84.1 KiB) downloaded 1013 time(s).
#2 Posted: 2020/2/12 12:07:47
"result above max ..." has no pertinent meaning in your project.
If you attempt "roots" on the numerator only ... "Units don't match"
No need to go further ... zap the units in the project.
#3 Posted: 2020/2/12 12:38:24
Joki720
Joki720
I made a mistake, there should be a solve function, in this place the same error
#4 Posted: 2020/2/12 14:57:49
Same answer: Units don't match.
How can you solve what you can't plot or evaluate ?
#5 Posted: 2020/2/13 07:44:15
1,355 likes in 2,271 posts.
You can use the function FindRoot() from the Nonlinear Solvers plugin. The function automatically assigns the solution to the variables.
Единицы измерения здесь не при чем.
2020-02-13 11_38_00-SMath Studio 0.99.7251 - [Poverochnyjj%20raschjot%20ehzhektora.sm_].png
Joki720 2020/2/14 13:06:00
#6 Posted: 2020/2/14 13:09:51
Joki720
Joki720
why do you use 0.2 and 0.5?
#7 Posted: 2020/2/14 13:57:29
127 likes in 342 posts.
Joki,
Martin could have drawn the two curves and graphically estimated the two solutions
#8 Posted: 2020/2/14 14:52:49
Joki720
Joki720
The solution must be automatic, plotting make and evaluating it is not appropriate
#9 Posted: 2020/2/14 19:34:05
OK ... don't plot => find min/max.
Don't you need a road to drive the car from point A to point B ?
#10 Posted: 2020/2/14 22:56:17
Common from ill posed construction.
Consider yellow up until you can plot that system(x,y):= ....
from there it should be solvable.
Poverochnyjj raschjot ehzhektora [zap Units, define the Undefined ...].sm (94.03 KiB) downloaded 852 time(s).
#11 Posted: 2020/2/15 06:37:16
Go on dreaming. If you are in non-linear systems and you can't find a symbolic solution (Maxima's Solve() got stuck when I tried) then you need numerical procedures for solution. These always need an initial guess (Newton-Raphson) or a search region (bisection). The various procedures just differ in how efficient or how robust they are. Some of them may have quite impressive radii of convergence for particular systems but none has infinite radius for all systems.
Furthermore, there remains the problem of uniqueness of a solution. The only solvers in SMath capable of providing multiple solutions are the
  • solve() finds all solutions of a single equation within a given range
  • Solve() from the Maxima plugin, which finds symbolic solutions.
Blatt21.sm (5.23 KiB) downloaded 1024 time(s).
#12 Posted: 2020/2/15 12:10:50
Quite right and not enough wrt complex roots.
Cubic solver Exercise.sm (38.97 KiB) downloaded 998 time(s).
#13 Posted: 2020/2/15 17:54:43
Always avoid ill posed polynomials.
#14 Posted: 2020/2/16 15:10:14
Jouko Tolonen
Jouko Tolonen
0 likes in 4 posts.
To OP's original question. I did get the same/similar error message on linear interpolation. One of the 5 required values had wrong value. After correcting no issues.
#15 Posted: 2020/2/16 20:47:13
What linear interpolation is doing here ?
If that document makes sense, return with comments.
Poverochnyjj raschjot ehzhektora [solve].sm (95.19 KiB) downloaded 852 time(s).
#16 Posted: 2020/2/16 23:09:30
I imagine you mean the very last part of the document.
The system looks ill posed, visit Solve Lecture last 3 days.
Poverochnyjj raschjot ehzhektora [solve, spline].sm (104 KiB) downloaded 890 time(s).
#17 Posted: 2020/2/17 09:35:01
... maybe we can leave it as such ... cleanup ?
Poverochnyjj raschjot ehzhektora [solve, spline].sm (110.44 KiB) downloaded 857 time(s).
Inst_Isentropic Discharge.sm (173.76 KiB) downloaded 988 time(s).
