Offset surface creation
Offset surface creation - Messages
#1 Posted: 2021/10/10 12:20:33
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
An initial surface is given, given by the "createmesh" function, which forms a
network with nodes.
Dyou want to create an offset surface, offset by an amount h from the initial.
The direction of displacement surface epends on the sign of h.
Sequence of calculation:
1.Restoring the normal from the nodal points of the initial surface and we get
the nodal points of the displaced surface.
2.We connect the resulting node points
The image is built on three-dimensional graphics and can be rotated with the mouse
4 users liked this post
Andrey Ivashov 2021/10/19 13:48:00, Oscar Campo 2021/10/20 18:42:00, Davide Carpi 2021/10/20 08:27:00, Alvaro 2021/10/10 20:58:00
#2 Posted: 2021/10/19 11:54:16
Renzo Choque
Renzo Choque
6 likes in 18 posts.
Thank you, this is helpful.
I have a question, How did you put the icon with the link?
#3 Posted: 2021/10/19 13:58:45
Fridel Selitsky
Fridel Selitsky
Hi,Rezorex.I put the icon with the link using the "hyperlink" insert.
Here is a link to an article from Mapleprimes
https://www.mapleprimes.com/posts/211000-Preparing-A-Parametrized-Surface-For
#4 Posted: 2021/10/20 05:22:00
1,123 likes in 1,795 posts.
Hi. Thanis Ber. A slightly different version, using only parametric functions.
Offset surface creation.sm (73.49 KiB) downloaded 1325 time(s).
Offset surface creation.pdf (917.17 KiB) downloaded 861 time(s).
Davide Carpi 2021/10/20 08:27:00, Fridel Selitsky 2021/10/20 08:34:00
#5 Posted: 2021/10/20 09:45:16
Fridel Selitsky
Fridel Selitsky
Thanks Alvaro, I continue to learn from you.
Fridel.
#6 Posted: 2021/10/20 13:31:05
Fridel Selitsky
Fridel Selitsky
Converting Surfaces to Solids
The solid is formed from the initial surface, the offset surface, and the
lateral surface that connects them. The lateral surface is formed by normals
reconstructed from the boundary nodal points of the initial surface.
Solid.sm (36.96 KiB) downloaded 1355 time(s).
Solid.pdf (309.58 KiB) downloaded 770 time(s).
Alvaro 2021/10/20 23:56:00
#7 Posted: 2021/10/20 20:43:17
Thanks ► Fridel, Alvaro
I don't have the courage to convert SS 6179 ... OK.
Keep up ... Jean.
Rotate 3D TREASURY_2 Parametric Explorer.sm (33.72 KiB) downloaded 1322 time(s).
#8 Posted: 2021/10/21 04:31:50
Hi Fridel. Thanks, great job. In the attached an alternate mesh. Its advantage is that it consists of a single coordinate matrix, so it can be manipulated more easily, with translations, rotations and deformations. As disadvantages, it does not look so good and there may sometimes be a wrong line, but I guess only one.
pSolid_alternate_mesh.sm (51.99 KiB) downloaded 1280 time(s).
pSolid_alternate_mesh.pdf (391.97 KiB) downloaded 717 time(s).
Fridel Selitsky 2021/10/21 05:07:00
#9 Posted: 2021/10/24 11:47:27
Fridel Selitsky
Fridel Selitsky
Normal to the surface on Rezonar's triangular mesh
NorSurAlvaro.sm (49.33 KiB) downloaded 1372 time(s).
NorSurAlvaro.pdf (623.77 KiB) downloaded 763 time(s).
Alvaro 2021/10/24 23:40:00
#10 Posted: 2021/10/24 14:59:18
By same token, did you manage constructing Delaunay ?
We had no chance in Mathcad. Cheers ... Jean.
#11 Posted: 2021/10/25 22:06:52
Hi. The same but with a different version for the triangular mesh.
NorSurAlvaro v2.sm (77 KiB) downloaded 1289 time(s).
Davide Carpi 2021/10/26 14:08:00, Fridel Selitsky 2021/10/25 22:55:00
#12 Posted: 2021/10/26 00:44:19
Fridel Selitsky
Fridel Selitsky
Examples of meshes with vertices
Nodes.sm (49.04 KiB) downloaded 1352 time(s).
Davide Carpi 2021/10/26 14:08:00, Alvaro 2021/10/26 05:20:00
#13 Posted: 2021/10/26 11:35:04
Fridel Selitsky
Fridel Selitsky
Animation with triangular meshes
pTriMeshAnimat.sm (22.68 KiB) downloaded 1306 time(s).
Alvaro 2021/10/26 12:24:00, Davide Carpi 2021/10/26 14:08:00
#14 Posted: 2021/11/11 06:54:12
Fridel Selitsky
Fridel Selitsky
Creating surface thickness with triangular meshes
thickness.sm (56.02 KiB) downloaded 1385 time(s).
thickness.pdf (732.98 KiB) downloaded 771 time(s).
