Hydraulic Radius
Hydraulic Radius - Program to solve the hydraulic radius based on the shape - Messages
#1 Posted: 2021/1/28 18:03:41
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
I have two forms of the program in this file. I would be happy
  • Get the program to work
In the file is a snippet of the MathCAD program I was using to confirm the structure
hydraulic radius.sm (213.85 KiB) downloaded 663 time(s).
#2 Posted: 2021/1/28 19:43:59
No luck Elsid: incorrect format ... empty document.
Make an image of your MCD, I might be able to check.
The attached document is fundamental to measure the volume
of partially filled thank [spherical, elliptical, sphere].
Inst_Segment Partial Random.sm (62.99 KiB) downloaded 636 time(s).
#3 Posted: 2021/1/28 20:24:14
Ruben Sidranski
Ruben Sidranski
Thanks for the attachment. I remember a similar MathCAD file
It bothers me that you cannot open my 0.99.7610 SM files ...
#4 Posted: 2021/1/28 21:08:58
IMHO, you may have one or more AV systems active.
No other Collabs reported "incorrect format" ???
In the circular, θ is unknown.
You may find something from Valery Goat radius .
Maths Goat Radius.sm (168.49 KiB) downloaded 641 time(s).
#5 Posted: 2021/1/28 21:25:26
Ruben Sidranski
Ruben Sidranski
I do have a θ per the screenshot above. Issue is in program structure.
Thank you for looking at this.
#6 Posted: 2021/1/28 22:30:56
churichuro
churichuro
28 likes in 79 posts.
hydraulic radius.sm (215.2 KiB) downloaded 598 time(s).
you have 2 little mistakes
shape must be a string and you are passing it an integer
and second I think that in the functions you should use the assignment (: =)
and not the symbol (=)
#7 Posted: 2021/1/28 22:56:05
Ruben Sidranski
Ruben Sidranski
Interesting.
I was playing with the equation definition ":=" in lieu of "="
I also have what appears to be the correct output from the DropBox list ... apparently not a string? ... your index DOES work
#8 Posted: 2021/1/28 23:05:13
Ruben Sidranski
Ruben Sidranski
@churichurro
I didn't notice that you deleted "continue" in the else part of my file. That was the issue!
"ELSE" needs to start the next "IF" loop, therefore it's nested. I'll clean it up and re-post
#9 Posted: 2021/1/28 23:48:36
Ruben Sidranski
Ruben Sidranski
Anyone have a good description, write-up, or weblink that derives these two formulas? (Not Wikipedia)
As promised above.
This made Manning so much easier. Thank you all
Hydraulic Radius Final.sm (16.32 KiB) downloaded 603 time(s).
#10 Posted: 2021/1/29 04:07:23
Martin_B
Martin_B
22 likes in 84 posts.
Thats's nearly a prime example for using cases instead of if/else:
#11 Posted: 2021/1/29 07:01:12
1,078 likes in 1,749 posts.
Hi. You don't need to divide by the units in the body of the procedure. Notice that z is the side slope, so it's dimensionless, equal to length / length, even eventually can have units, like mm/m. This is, given that z is the horizontal change per unit vertical change, it's usual to use one unit for horizontal change but another to the vertical change.
#12 Posted: 2021/1/29 09:32:53
Anyone have a good description, write-up, or web link that derives these two formulas? (Not Wikipedia)
Wikipedia has turned about useless in too many search !
Visit this site + calculator.
https://www.ajdesigner.com/phphydraulicradius/hydraulic_radius_equation_pipe.php
#13 Posted: 2021/1/29 09:44:42
... BTW, perimeter of the rectangular, triangular, trapezoidal
easy from the polygon maths, somewhere in Samples, easy to renew
from my file. Please let us know.
For the partially filled circular, there is no escape from the Segment.
The only measurable is the height of the segment.
Have a good day project ... Jean.
#14 Posted: 2021/1/29 09:50:18
1,532 likes in 1,838 posts.
Some time ago I made similar calculations.
Hydraulic calculation (rus).sm (42.41 KiB) downloaded 650 time(s).
#15 Posted: 2021/1/29 09:53:23
Ruben Sidranski
Ruben Sidranski
I've never heard of or used "cases"
Update, to add "IFs", Jean answered the question: click right hand most place holder, coma twice for one more if... again coma twice like before. Will be dissecting this function. Thanks to others who posted sheets.
#16 Posted: 2021/1/29 09:53:47
#17 Posted: 2021/1/29 11:35:38
Yep. Here with correct units:
Hydraulic Radius Final.sm (15.64 KiB) downloaded 608 time(s).
#18 Posted: 2021/1/29 11:41:01
... from Polygon Area/Perimeter
Inst_Hydraulic Radius.sm (22.54 KiB) downloaded 651 time(s).
#19 Posted: 2021/1/29 12:17:35
Ruben Sidranski
Ruben Sidranski
Alvaro,
I tend to use units wherever and whenever possible. I see what you mean with "z". This IS unitless, thank you for correcting this. I fixed the formula to omit units on my sheet.
I now see the units comment clearly
#20 Posted: 2021/1/29 16:31:45
... modular, piece-wise from source unit-less.
Any polygon, partially filled thank.
Measuring the segment 'h partial filled' is another story.
Inst_Hydraulic Radius.sm (65.2 KiB) downloaded 624 time(s).
