Hydraulic Radius - Program to solve the hydraulic radius based on the shape - Сообщения
- Get the program to work
hydraulic radius.sm (213,85 КиБ) скачан 1207 раз(а).
Make an image of your MCD, I might be able to check.
The attached document is fundamental to measure the volume
of partially filled thank [spherical, elliptical, sphere].
Inst_Segment Partial Random.sm (62,99 КиБ) скачан 1202 раз(а).
WroteThanks for the attachment. I remember a similar MathCAD file
It bothers me that you cannot open my 0.99.7610 SM files ...
IMHO, you may have one or more AV systems active.
No other Collabs reported "incorrect format" ???
In the circular, θ is unknown.
You may find something from Valery Goat radius .
Maths Goat Radius.sm (168,49 КиБ) скачан 1216 раз(а).
Thank you for looking at this.
you have 2 little mistakes
shape must be a string and you are passing it an integer
and second I think that in the functions you should use the assignment (: =)
and not the symbol (=)
Interesting.
I was playing with the equation definition ":=" in lieu of "="
I also have what appears to be the correct output from the DropBox list ... apparently not a string? ... your index DOES work
I didn't notice that you deleted "continue" in the else part of my file. That was the issue!
"ELSE" needs to start the next "IF" loop, therefore it's nested. I'll clean it up and re-post
As promised above.
This made Manning so much easier. Thank you all
Hydraulic Radius Final.sm (16,32 КиБ) скачан 1153 раз(а).
WroteAnyone have a good description, write-up, or web link that derives these two formulas? (Not Wikipedia)
Wikipedia has turned about useless in too many search !
Visit this site + calculator.
https://www.ajdesigner.com/phphydraulicradius/hydraulic_radius_equation_pipe.php
easy from the polygon maths, somewhere in Samples, easy to renew
from my file. Please let us know.
For the partially filled circular, there is no escape from the Segment.
The only measurable is the height of the segment.
Have a good day project ... Jean.
Hydraulic calculation (rus).sm (42,41 КиБ) скачан 1227 раз(а).
WroteThats's nearly a prime example for using cases instead of if/else:
I've never heard of or used "cases"
Update, to add "IFs", Jean answered the question: click right hand most place holder, coma twice for one more if... again coma twice like before. Will be dissecting this function. Thanks to others who posted sheets.
WroteWroteThats's nearly a prime example for using cases instead of if/else:
Yep. Here with correct units:
Hydraulic Radius Final.sm (15,64 КиБ) скачан 1159 раз(а).
WroteHi. You don't need to divide by the units in the body of the procedure. Notice that z is the side slope, so it's dimensionless, equal to length / length, even eventually can have units, like mm/m. This is, given that z is the horizontal change per unit vertical change, it's usual to use one unit for horizontal change but another to the vertical change.
Alvaro,
I tend to use units wherever and whenever possible. I see what you mean with "z". This IS unitless, thank you for correcting this. I fixed the formula to omit units on my sheet.
I now see the units comment clearly
Any polygon, partially filled thank.
Measuring the segment 'h partial filled' is another story.
Inst_Hydraulic Radius.sm (65,2 КиБ) скачан 1152 раз(а).
