An Help with ODE system - Messaggi
So basically I have two ODE with into them some parameters that changing in time...Obviously, nothing work and I would like to have a little bit of help.
Ok, I'm not the best at explaining this, so I attach the file and I hope that someone can give me some good advice to make this thing work!
Prova modello permeabilita.sm (128,28 KiB) scaricato 1218 volta(e).
WroteNow I try to fix it and, in general, to be more ordered.
If you describe the original system, it becomes clearer what you want to get.
WroteWroteNow I try to fix it and, in general, to be more ordered.
Basically, this set of equations should describe the evolution of the atmosphere inside a packaging.
So we have O2i which is the evolution of oxygen inside the packaging, which decreases because inside there is a fruit that breathes.
Co2i is the evolution of CO2, which increases because the fruit emits it.
ro2 and rco2 would be the breathing of the fruit, which also changes according to the atmosphere of the packaging.
Is a model that you can find in the article:
Modeling respiration–transpiration in a modified atmosphere packaging system containing blueberry
Yoonseok Song a, Nick Vorsa b, Kit L. Yam a,*
And yes...probably isn't the best choices for a first try but unfortunately its what I need
Now I try to fix a little bit better the file and we will see what other problem come out :d
WroteWroteSo we have O2i which is the evolution of oxygen inside the packaging,
Most interesting/waiting to taste the fruit from your project !
hoping they are not poisoned! :d
In your opinion this way the value of rco2 change with the new value of Co2i or it remains the initial value that I have set?
Prova modello permeabilita.sm (129,47 KiB) scaricato 1129 volta(e).
Modeling respiration-transpiration in a modified atmosphere packaging system containing blueberry (uni).sm (15,31 KiB) scaricato 1177 volta(e).
Modeling respiration-transpiration in a modified atmosphere packaging system containing blueberry (uni).pdf (61,29 KiB) scaricato 676 volta(e).
Modeling respiration-transpiration in a modified atmosphere packaging system containing blueberry (2002).pdf (349,8 KiB) scaricato 1770 volta(e).
.png)
Now I work a little on this thing and we will see what progress I'm able to do.
I'm sure that in the end, it will work!
WroteNow I work a little on this thing and we will see what progress I'm able to do.
AbsTol, RelTol is very specific w/o project application(s)
The attached is suggestive of exploring more.
ODE GearsBDF Undocumented.sm (18,75 KiB) scaricato 1152 volta(e).
WroteFrom the web visit, if 9 out of 10 same link are "404",
the originator is negligent, not to say "not trustable"
Paying $ to Elswier ... my ass !
No need for all that jargon, just give what you want to control,
I will close a control loop to optimum degree of accuracy !
Sorry, for sure is for my bad english, I'm missing the meaning.
What I want to obtain is the evolution of the atmospheric concentration and respiration in the packaging.
So something like
That is more or less what uni has done
Wrote... blue berries that have been hyper-frozen are much better
than fresh blue berries. I get my fresh blue berries from next farmer,
enjoy fresh and don't freeze. Never purchase blue berries from California
in winter Quebec. Just leave them for the naive shoppers.
Lol..actually I will have to use this for things related to strawberries...I don't even like strawberries...end at the end of the day the thing that I have a real interest to see is how damn big must be the pore in the film for avoid to reach the 0% of O2
WroteYou can set breakpoint on line in D(t,oco) and you will see how values changed.
Yes, I have to study a little bit about this function of smath...to be honest, all the functions!
In general, there is something that doesn't work properly, because the chart describes the depleting and the increment almost linear until the O2 don't reach 0. After that point the CO2 increment start to being described in a "realistic way
I mean, I'm expecting to see something like that (the thick blue lines)
I have demonstrated how you can solve this problem. Now you just need to correctly describe it in terms of the program. I wish you success.
WroteYou need to set real values for all variables. It is not entirely clear from the article what values to use. I can't help here, because I'm not familiar with this task.
Thank you a lot my friend, I really appreciate the help.
When all will be done I will post here the program, so that it can be useful for everyone.
Prova modello permeabilita.sm (129,71 KiB) scaricato 1216 volta(e).
