An Help with ODE system
An Help with ODE system - Messaggi
#21 Pubblicato: 24/11/2020 12:58:16
francesco88
francesco88
1 apprezzamenti in 34 post.
... up to You the expert !
Prova modello permeabilita.sm (129,71 KiB) scaricato 1216 volta(e).
yap, there is something in the data that screwup the ro2 and rco2 evaluation
Damned fruits, things whit dead things are much more simple
Veniamo da molto lontano e andiamo molto lontano! Palmiro Togliatti
#22 Pubblicato: 24/11/2020 14:01:56
Do you mean you have red ?
Quite right about dead fruits.
Here in Québec, the most poisoned strawberries ... 0 poisoned blueberries.
The most idiotic are kiwis from New Zealand, they grow in Québec smaller size, succulent.
I was reading the paper Adams-Moulton, to some casual exception, they are all
same ballistic approximation ... dn_GearsBDF runs 5 to 10 times faster.
From the attached, please report if you have red evaluation.
If so, it would indicate a bug in your latest SS version.
At the first eventual red occurrence, please attach an *.PDF to see the guilty.
See you soon ... Jean
Prova modello permeabilita.sm (170,57 KiB) scaricato 1158 volta(e).
#23 Pubblicato: 24/11/2020 14:33:18
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
No, Jean, do not mislead the man. If something doesn't work, it doesn't mean there is an error. There are alternative probabilities.
#24 Pubblicato: 24/11/2020 15:04:57
I presumed my document didn't work as given.
Let's see what does not evaluate.
Cheers Viacheslav ... Jean
#25 Pubblicato: 24/11/2020 15:10:16
francesco88
francesco88
Yup, isn't a problem of code, is a problem of data.
Now I'm trying to make something different for having an idea of the behaviors.
Basically, I would like to evaluate the two respiration rate at different concentrations, 0%, 5%, 10%, 15% and 20%, so to be able to leave it constant in the ODE splitting the curve into 3 portions.
In any case, there is something in this model that I haven't understand for sure.
#26 Pubblicato: 24/11/2020 18:51:34
francesco88
francesco88
Ok, after a little bit of scavenging to find the right data, seems that the implementation of uni works quite well!
I have really to thank you a lot for your help, and also I need to understand better how to use gearsbdf and in general all the things that you has write there!
Now I will add other things and reupload the file.
#27 Pubblicato: 24/11/2020 18:54:51
0%, 5%, 10%, 15% and 20% ...
In any case, there is something in this model that I haven't understood for sure.
As given, your system depends upon 9 parameters, of which many may be interactive.
In Mathcad/Mathsoft, we can optimize a DE wrt some parameters of the DE.
Up to 4 parameters is no sweat. See image in the attached document.
This is due to the Mathsoft proprietary bloc Given/Minerr, not known possible in Smath.
On the other hand, in Smath, given a data set, we can attempt to fit a model function.
Just to fit a model, the data set need not be clean. Do you have experimental data ?
In Mathcad, you can set the ODEsolve as a function, if that is possible our friend
Viacheslav will surely reply. On my side, will cogitate.
ODE Aminohippuric MCD.sm (164,35 KiB) scaricato 1139 volta(e).
#28 Pubblicato: 24/11/2020 19:10:26
francesco88
francesco88
This is a really interesting material and I thank you a lot for have share it!
I really need to become more familiar with the software.
In your opinion the book SMath for Physics by Bernard V Liengme is a good investment of time and money?
#29 Pubblicato: 24/11/2020 23:02:14
Sorry, I'm not familiar with the book, just aware of it.
Hopefully, Smath Community will advise ... I guess yes.
If not exactly wrt your project, otherwise sure educative.
#30 Pubblicato: 25/11/2020 07:47:11
francesco88
francesco88
eheh We will see, for his price I suppose that I can take the risk.
#31 Pubblicato: 25/11/2020 08:34:28
Gruppo: Moderator
I would recommend just looking at the video courses that are currently available:
- Simple Introduction in SMath with Tanya J. Laird;
- Curso SMath Studio CEI;
- Curso de SMath;
- Marcelo Ortiz Plá.
SMath Suite: A Primer (pdf)
SMath Suite: A Primer (documents)
SMath Suite. A Primer (Bernard Liengme).pdf (2,17 MiB) scaricato 1004 volta(e).
#32 Pubblicato: 25/11/2020 09:56:38
Very minimalist for new Smath user, not familiar with CAS software.
You will find infinitely more stuff/project in Samples Repository.
#33 Pubblicato: 25/11/2020 10:17:47
francesco88
francesco88
Thank you again for all your goods advice.
I had always used an Hp50g, paper, and pen but now I really need to make this step up.
So, I will study well the video and the materials on the forum.
#34 Pubblicato: 29/11/2020 14:32:11
francesco88
francesco88
Ok, I started to understand a little bit better how smath work and I really hope it will be able to do what I need because I really like it.
Now, sorry for bothering you again, I would like to have another little help.
To have the model properly working I need to add some other pieces, and I made some tentative to put these pieces is with some uhmmm "horrible" results.
Now, If you can give me feedback on what I have done on pages 2-3 would be lovely
I would like to understand if what I have done is totally wrong or if there are some "grammatical" errors.
So any Help is welcome!
Modeling respiration-transpiration FRA2.sm (46,51 KiB) scaricato 1111 volta(e).
#35 Pubblicato: 29/11/2020 18:11:39
1. Forget AbsTol, RelTol ... there is no known use, specific to dn_GearsBDF
2. mr.pr not defined
3. Construct the DE piece wise
What you have is so far not same as the previous work
The original *.PDF is so much jargon ... their DE is what you should use.
I can't follow your D(t,oco).
Prova modello permeabilita.sm (158,5 KiB) scaricato 1112 volta(e).
#36 Pubblicato: 29/11/2020 18:22:17
francesco88
francesco88
Thank's a lot for all the observations!
I thought to had to define m.pr in the stack XD my bad
Now I try to rewrite all in a more clear and comprehensible way, maybe with some comment!
#37 Pubblicato: 29/11/2020 20:03:51
... the DE system from the paper. Originally, you composed two DE.
That paper is damned hard to follow, probably a plagia itself.
#38 Pubblicato: 29/11/2020 21:25:48
francesco88
francesco88
Yes, in reality, that two DE was just a first step.
What I need to do is just a little bit more complex than what is written in the first paper, because there are a lot of things that have an influence on the mass transfer in a package.
So, what I'm trying to do is to add a piece at once.
Now, in the last file there are in oco 5 pieces.
[O.2i (oxygen in the package),
C.O2i (CO2 in the package),
m.pr (amount of water that permeate through the plastic film),
W.1 (weight loss of product due to the loss of water),
HR1 (humidity in the package]
Now, unfortunately, all these factors are correlated...and more are needed for describing all the system.
I'm trying to write in a very simple way what I would like to do on the smath file, and I hope it will be possible.
Honest, more I look at the sheet and more it seems a mess to me.
I need to find a way to make it more simple
Presentation1.pdf (107,23 KiB) scaricato 647 volta(e).
#39 Pubblicato: 30/11/2020 03:39:42
Gruppo: Moderator
It is possible to solve the system in this way, i.e. integrating each equation separately. But here you need to be very careful.
Modeling respiration-transpiration in a modified atmosphere packaging system containing blueberry 2 (uni).pdf (83,13 KiB) scaricato 687 volta(e).
Modeling respiration-transpiration in a modified atmosphere packaging system containing blueberry 2 (uni).sm (18,4 KiB) scaricato 1215 volta(e).
Modeling respiration-transpiration in a modified atmosphere packaging system containing blueberry 2 (uni).png
Alvaro 30/11/2020 09:49:00
#40 Pubblicato: 30/11/2020 03:54:05
Gruppo: Moderator
Euler is still good.
