Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Messaggi
Curiously enough, I think that this didn't happened in Linux (it worked only export correctly) but I want to do more tests in Linux.
edit:
yes i had a plugin disabled when starting smath but dont know which one yet. i'll edit this post later on.
The Full Package issue is caused by the ClosedXML library when SMath loads the plugins in the "Plugin" folder (if you put only the ClosedXML.dll file inside the plugin folder of a clean installation the message will appear), the OpenDocument issue by the Ionic.Zip library calling the related functions, I don't know if the 2 bugs are the same or simply similar...
WroteIt seems that Martin did not have this problem o_o
I don't know...
An early Post probably related: Issue SMATH Error - Won't Load Existing XMCD File (Build 0.96.4868) - XMCD File created by previous version will not open in new version
WroteI've just tried Martin's distro with the full plugin and got the same error as you, everything is broken (all samples in docs' plugin) with the same ionic.zip error.
edit:
I tried it as well in Xubuntu using Martins' version. No errors about Ionic.zip. Save as ODT is working, but it seems that only the text can be saved. I did not manage to save formulas and plots.
I do not know why some of your post have to be approved sometimes
WroteHi Radovan
The Full Package issue is caused by the ClosedXML library when SMath loads the plugins in the "Plugin" folder (if you put only the ClosedXML.dll file inside the plugin folder of a clean installation the message will appear), the OpenDocument issue by the Ionic.Zip library calling the related functions, I don't know if the 2 bugs are the same or simply similar...WroteIt seems that Martin did not have this problem o_o
I don't know...
Sorry, I forgot that ClosedXML thing
Repository: Debian Stable; Desktop manager: Gnome2.3, btw SMath is very responsive in this manager.
This file contains the plugin docs and some screenshots showing errors while running the program.
An this is the plugin tested in Zorin(ubuntu)
http://www.mediafire.com/?p4ehqsr6pgs2vwl
WroteHi Radovan
I don't know...
Just to try to conclude something about this. It seems to me that the same (or similar) problem comes with v0.96 and this plugin and the mcadEFI plugin by uni . As I understood this well, there will be fixed on the next SMath release. Until then these plugins are "off" the use, or to continue using them in 0.95. I hope I was right about it.
By the way, the activity on the Forum increased quite a lot, almost hard to follow
WroteJust to try to conclude something about this. It seems to me that the same (or similar) problem comes with v0.96 and this plugin and the mcadEFI plugin by uni . As I understood this well, there will be fixed on the next SMath release. Until then these plugins are "off" the use, or to continue using them in 0.95. I hope I was right about it.
By the way, the activity on the Forum increased quite a lot, almost hard to follow. I am not complaining, just contrary
If you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody
WroteIf you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody
Thank you uni, this workaround solve all the issues
BTW this make dirty the SMath's installation folder, so it's really better to not use it if not strictly required.
best regards,
w3b5urf3r
WroteWroteIf you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody
It does not work for me, or I did not figure out
- change of requirements: SMath Studio 0.96.4875 (07 May 2012)
- relative path improvements;
- ODS export vs symbolic optimization fix;
- patch on ODT embedded images for Linux users;
- SMath Viewer compatible.
best regards,
w3b5urf3r
Steve
WroteThanks. Seems to work fine now.
Steve
You're welcome :d
- XLSX features moved away (see Xlsx Import/Export plugin )
- plugin added to the Gallery (Latest Nigthly build)
- Added Guid (after installing the plugin, a message should appear opening old files, just skip it and save again the file)
best regards,
Davide
- fixed: SMath Studio 0.96.4909 (10 June 2013) vs XeLaTeX saves
I can't reproduce your issue (win7 x64 - SMath 0.96.4909)
Are you sure that this plugin cause the issue? copy and paste the red string ( %APPDATA%\smath\extensions\plugins ) in your windows start menu, press the return key and then delete the plugin folder (5dce7298-9e5f-4120-9a2e-49b16daa02a3) then try to start SMath again.
Davide
The problem is related to some worksheet (empty file, with figures, with text, with math), some machine, or is general?
Have you the same issues with the unofficial portable version?
You could try to share here your system informations (Development Tools plugin > System informations > save as... > attach here the file)
![2014-01-04 01_47_38-SMath Studio Desktop - [Page1].png](/it-IT/files/Download/a8AMrH/2014-01-04-01_47_38-SMath-Studio-Desktop---[Page1].png)
