Data Exchange plugin
Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Messaggi
#141 Pubblicato: 23/01/2016 08:53:32
Gruppo: Moderator
Beautiful function your FindReplace function Jean
I think he is looking for a general search & replace, both for math and text and able to acting on the whole worksheet.
I'm working on something, search works pretty fine with small limitations
sergio 23/01/2016 09:04:00, Radovan Omorjan 23/01/2016 09:10:00, ioan92 23/01/2016 09:01:00
#142 Pubblicato: 05/04/2016 06:25:44
127 apprezzamenti in 342 post.
Hello Davide,
I have problems with the export XeLaTeX.
First it is highlighted exception
Proceeding is inhibited the choice of options
Proceeding is nevertheless produced a tex file
You must still add the following line in the markup to fill in XeLaTeX
\newcommand{\defeq}{\coloneq} % SMath 'define equal' symbol
PS some addition function is not implemented, however, the qualitative result of the prints obtained is much higher than that of normal export pdf. I would hate a little if this project was abandoned
[albumimg]1437[/albumimg]
#143 Pubblicato: 05/04/2016 16:12:31
Gruppo: Moderator
Ciao Sergio,
Hello Davide,
I see, seems something related to multithreading vs Forms. I have to ask Andrey, but I think that I have to remove the dialog from the save flow.
The project is not abandoned, but you know, there are a lot of plugins and I have to find a little bit of time for each one. I'll implement the missing functions ASAP.
sergio 06/04/2016 04:07:00
#144 Pubblicato: 06/04/2016 04:18:02
Ciao Davide,
with regard to functions not implemented do not worry there is always the possibility to act manually (thank you for the tremendous efforts of multiple plugins). For the mistake the question is more annoying: Andrey hopefully give a solution.
#145 Pubblicato: 08/04/2016 12:03:26
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- SS 0.98: fixed crash on save due to the Forms vs MTA;
- ODT, TEX files: added Command Prompt flags (see documentation in 1st post);
- ODT, TEX files: added more functions (vectorize, Floor, Ceil, at, cases, ternary booleans, absolute-definition's functions), fixed glitches in functions' names in ODT files, minor fixes & improvements;
- TEX files: all worksheet's metadata are now stored in the \doc***** variables;
Mostra spoiler
sergio 08/04/2016 12:50:00
#146 Pubblicato: 08/04/2016 14:15:18
Hello
the problem indicated in the post #141 has been resolved
Davide Carpi 08/04/2016 14:17:00
#147 Pubblicato: 07/06/2016 04:27:18
angryTeenages
angryTeenages
0 apprezzamenti in 3 post.
How can i download plugin or dll file and then install it to my PC and save .sm file in ODF, not in ODT (ODF Text document)?
I need this to be a formulas that can easy edit in MS Word lately.
Please, give straight link on plugin or help me to solve this promblem.
kursach SG.sm (376,93 KiB) scaricato 1581 volta(e).
#148 Pubblicato: 07/06/2016 04:48:30
Mike Kaganski
Mike Kaganski
184 apprezzamenti in 434 post.
@mayIcomeiN, здравствуйте
To download and install it, you need to go to menu Tools->Plugins, there make sure that "Plugins" is selected in the left pane, then click the "Local Storage" button over the plugins list, select "Online Gallery" and find the plugin there. Select it, and click "Install" at the bottom of the window.
If you want "ODF", but not "ODT", then there is no such thing as pure "ODF". There are a number of Open Document Formats available, among them: ODT for text documents, ODS for spreadsheets, ODP for presentations, ODG for drawings, etc. What do you need specifically? MS Word since 2007SP2 is able to open ODT, Excel understands ODS, ... so what do you need? I cannot tell if they will import formulas OK, but that's up to you to test.
С уважением, Михаил Каганский
#149 Pubblicato: 07/06/2016 05:13:10
angryTeenages
angryTeenages
Hello.
If you may, please answer me in russian.
There is no plugin "DataExchange" or similar with "odf,odt" in discription.
I already have plugin who called "DataExchange", but he dont' do his own case in particular that announced there
ODF Formulas (to export variables and functions);
I want the formula looks like this Clipboard01 - kopija.jpg.
But after i saved my file in .odt ( ODF text doc.) wordpad told me that there is content who was incorrectly
displayed.When i tried to open file in Word (2007 version) it cant be open beacuse Clipboard01.jpg
Translation: "Cant open file Office Open XML because of errors in his content"
#150 Pubblicato: 07/06/2016 05:29:45
Mike Kaganski
Mike Kaganski
Hello.
Хорошо
Citazione
Это потому, что ...
Citazione
Если какой-то плагин уже установлен, он не отображается в диалоге, пока к нему не выйдет обновление (тогда он будет подсвечен).
Citazione
I want the formula looks like this ...
displayed.When i tried to open file in Word (2007 version) it cant be open beacuse ...
Это не плагин "не делает того, что заявлено", а хреново работает MS Office. То, что WordPad не может его прочитать - так он вообще мало что может. А вот 2007 версия офиса, в которой появилась впервые поддержка ODF, получила очень плохую репутацию за некорректную поддержку - Майкрософт тогда вообще обвинили, что они саботируют ODF такой поддержкой.
Вот файл, открытый MS Word 2013 и пересохранённый в docx: kursach SG.docx (112,71 KiB) scaricato 847 volta(e).
Davide Carpi 07/06/2016 07:59:00
#151 Pubblicato: 07/06/2016 05:44:35
angryTeenages
angryTeenages
Благодарю за поддержку!
Thank for help!
#152 Pubblicato: 12/08/2017 08:10:18
Gruppo: Moderator
The importData.ODS function does not work in SMath 0.98.6398 (error message: function not defined)
Is the plugin not supposed to work in the latest beta?
Davide Carpi 14/08/2017 05:06:00
#153 Pubblicato: 16/08/2017 14:53:12
Gruppo: Moderator
Fixed, thank you!
PLUGIN UPDATED
Martin Kraska 16/08/2017 17:51:00
#154 Pubblicato: 13/10/2017 07:44:09
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.98.6484 and later
  • Fixed open document format support under MONO;
#155 Pubblicato: 16/10/2017 12:17:04
timgow
timgow
0 apprezzamenti in 27 post.
Hello there,
Is there a method for using round() with exportDataCSV?
Perhaps I need to loop through the multi dimensional array and operate on each entry using round(), ahead of using exportDataCSV.
Please point me in the right direction for a robust method.
Tim
#156 Pubblicato: 16/10/2017 12:38:09
Gruppo: Moderator
You can use a loop or vectorize() over the round function
#157 Pubblicato: 17/10/2017 07:54:18
Gruppo: Moderator
  • Fixed wrong numerical output;
#158 Pubblicato: 17/10/2017 10:01:06
Utilities Matrix roundup_n.sm (24,9 KiB) scaricato 1541 volta(e).
#159 Pubblicato: 17/10/2017 16:40:48
In the last Hermite polyline, it does not understand
vectorising roun(col,n) over specific col ... done otherwise.
#160 Pubblicato: 08/02/2018 18:00:47
Gruppo: Moderator
I love SMath, I really do.
But nothing can beat LaTeX if it is the print quality.
Converted .sm to .tex with SMath Studio "Save As->TeX".
Used MiKTeX, altered tex file a little bit and compiled with XeLaTeX.
Just for fun.
tex.zip (97,82 KiB) scaricato 691 volta(e).
Radovan Omorjan 09/02/2018 03:57:00, Davide Carpi 09/02/2018 05:33:00
