Data Exchange plugin
Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Messaggi
#181 Pubblicato: 23/05/2021 07:44:04
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.99.7808 and later
  • fixed encoding/decoding issues;
  • refactoring;
#182 Pubblicato: 05/08/2021 10:04:01
Stefano
Stefano
0 apprezzamenti in 22 post.
when saving as odt with the option to convert to libreoffice math object, negative quantities loose the minus sign only if the haven't any other element in front of them. For example:
Citazione
a:=4-9=-5
it get converted to
Citazione
a:=4-9=5
For context, I just discovered this app so it could be that I am simply ignoring something obvious.
File non trovato.->File non trovato.
#183 Pubblicato: 05/08/2021 17:25:52
Gruppo: Moderator
Seems a bug in the plugin, thank you for reporting it
#184 Pubblicato: 24/12/2021 01:52:45
susilo widyatmoko
susilo widyatmoko
5 apprezzamenti in 9 post.
can I use this plugin (csv export) in viewer/exe file? so user can get output from exe file
#185 Pubblicato: 29/12/2021 20:16:47
Gruppo: Moderator
Hello [userlink]Susilo Widyatmoko[/userlink],
Yes, you can. If you want to let the user choose a path, there is the path picker region, otherwise you might choose a default output, f.e. if you choose an empty string as third argument ("") the file will be created next to the executable.
#186 Pubblicato: 03/06/2022 08:56:14
RaiHil
RaiHil
0 apprezzamenti in 2 post.
Hello Davide,
thank You for Your very useful Plug-in!
I use it regularly to paste my Smath calculations into MS Word.
In order to be able to arrange and organize formulas and text better, I use text regions.
Unfortunately, text regions containing formulas are not saved properly in the *.odt files.
Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files?
Thank You verry much
Raimund
#187 Pubblicato: 06/06/2022 13:51:47
Gruppo: Moderator
Hello [userlink]RaiHil[/userlink]
I'll look into it, although last time I've checked nested regions weren't easy to manage plugin-side.
#188 Pubblicato: 09/06/2022 11:52:55
RaiHil
RaiHil
Thank you, I appreciate your effort!
