Maxima Plugin
Maxima Plugin - Mensajes
#281 Publicado: 24/3/2020 11:10:39
netsonicyxf
netsonicyxf
2 me gusta en 79 mensajes.
I have a portable version of Smath 0.99.7251. The Maxima is under D:\Program Files\Math Tools\SMath Studio\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\1.98.7100.23756\
I put the above path into insert->settings, but it show "Cannot find maxima.bat"
Did you install Maxima? If not, follow the link in my signature and see the instructions for installing and configuring Maxima. The plugin just provides the interface.
Thanks. I installed Maxima 5.42.2.
But still can't get result. SM file attached.
maxima.sm (2,97 KiB) descargado 1701 vez(es).
#282 Publicado: 24/3/2020 13:01:31
Why so much trouble for ordinary stuff vs Smath Native ?
#283 Publicado: 24/3/2020 22:22:03
netsonicyxf
netsonicyxf
Thanks Jean, but can't get result either.
error:"x not defined"
maple.sm (2,01 KiB) descargado 1706 vez(es).
#284 Publicado: 25/3/2020 0:32:16
CBG
CBG
78 me gusta en 312 mensajes.
put the optimization to symbolic or none
Carlos
#285 Publicado: 25/3/2020 6:04:40
Grupo: Moderator
You have to set Optimization to Symbolic or None to display symbolic results. You can also press Ctrl+. instead of = to get symbolic results from an expression.
@Jean: maple isn't SMath native, you see that if you try it in the cloud version. Also, the legal/license status of the embedded maple executable has never been clarified. There might be people who care about this.
#286 Publicado: 25/3/2020 9:46:52
YES Martin. On the other hand, Maple is the former Macsyma
joint venture MIT/UT [University of Toronto].
Hard to legal/license to freeware Smath.
The very core Maple is largely due to Angot ancestor.
Thanks Martin ... Cheers/Jean
#287 Publicado: 8/10/2020 7:00:15
Grupo: Moderator
This is an example on how to control the assumptions used for symbolic integration in Maxima.
1-2-4 Widerstandskrafte.sm (12,13 KiB) descargado 1693 vez(es).
sergio 8/10/2020 15:45:00, IVR 10/10/2020 12:24:00
#288 Publicado: 10/10/2020 20:52:49
Get more from less ... typical.
#289 Publicado: 23/11/2020 16:28:27
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
Animation in Maxima
Плагин Maxima не имеет встроенной возможности анимации.
Для создания анимации использовалась программа
https://en.smath.com/forum/yaf_postsm48012_Graph-animation.aspx#post48012
Для записи Gif файла использовалась программа GifCam.
povorot1.sm (74,29 KiB) descargado 1672 vez(es).
SpiralMaxima.sm (45,77 KiB) descargado 1683 vez(es).
Andrey Ivashov 23/11/2020 17:36:00, Martin Kraska 23/11/2020 18:06:00, IVR 25/11/2020 7:19:00
#290 Publicado: 23/11/2020 16:35:47
Fridel Selitsky
Fridel Selitsky
Visualization of animation steps
Slider.sm (159,76 KiB) descargado 1734 vez(es).
#291 Publicado: 23/11/2020 18:15:12
Grupo: Moderator
Animation in Maxima
Very nice. Here is a version with absolute variables (names starting with ~, not easy to input with german keyboard) for execution counter. BTW, the original version reads temp storage before it is written. This throws an error similar to what would happen if I had not checked for a being undefined.
povorot1_kr.sm (75,16 KiB) descargado 1712 vez(es).
Fridel Selitsky 23/11/2020 19:10:00
#292 Publicado: 23/11/2020 18:35:41
Fridel Selitsky
Fridel Selitsky
Vibrations of a rectangular membrane
Vibration Restangular Membrane.sm (184,22 KiB) descargado 1677 vez(es).
Andrey Ivashov 23/11/2020 19:03:00
#293 Publicado: 23/11/2020 19:10:35
Fridel Selitsky
Fridel Selitsky
Thanks a lot, Martin. Wonderful! I was not aware of the IsDefined function.
#294 Publicado: 24/11/2020 11:09:18
Thanks Champions: Martin, Ber7
#295 Publicado: 24/11/2020 17:37:40
Fridel Selitsky
Fridel Selitsky
Vibrations of a circular membrane.The general case
https://en.smath.com/forum/yaf_postst11431_Vibrations-of-membranes.aspx
CircleAntisiimmetr.sm (252,68 KiB) descargado 1685 vez(es).
#296 Publicado: 6/5/2021 21:12:01
Arie
Arie
94 me gusta en 285 mensajes.
We really need a linux port
I agree. Maybe, just an adjustment of the command line for establishing the socket connection is required. Under Windows I use
maxima-installation-path/bin/maxima.bat -l sbcl -s
This requires
- the .net socket stuff and process control to work under mono,
- a unicode-proof lisp compiler to be installed (which accepts utf-8 socket encoding), under win the only one is steel bank common lisp (SBCL).
Also, I need to know the name of the maxima process for detection of active maxima processes via System.Diagnostics.Process.GetProcessesByName(name). This is required to identify the pid for later kill. Under windows this might be "maxima" or "lisp" or "sbcl". This has changed over the years and may be different under linux.
The plugin might work even as it is, if the maxima startup script is renamed to maxima.bat.
Any information from the linuxing SMatheers is welcome.
BTW, there is a maxima build for android as well...
EDIT: It would also help, if someone could explain me how to build and debug the plugin under Linux. Under Win, I use VS 2015 with the project as found in the SVN repository. Otherwise I need to blindly make changes under win and install and test under linux. This would be a huge drawback compared to the win-only workflow, where compiling and running SMath with the new build in the debugger is just a push of a single button...
Bringing up this topic again. Has there been any progress on this?
Is this at all helpful for building the plugin in linux?
https://dotnet.microsoft.com/learn/dotnet/hello-world-tutorial/intro
#297 Publicado: 7/5/2021 5:36:07
Grupo: Moderator
This requires
There is no progress from my side. Also, for me, there is no chance of digging into it for at least one more year. If someone wants to do that now, I am ready to help. Yet I think that the plugin is merely a demonstrator of what could be done. It lacks a systematic and clean approach, due to lack of proper knowledge on SMath, Maxima and C# internals. It definitely requires a lot of refactoring or re-design from scratch before extending it.
#298 Publicado: 13/5/2021 15:44:42
pk_mechanical_eng
pk_mechanical_eng
0 me gusta en 3 mensajes.
Hi Guys,
I'am using Smath for quite a while and already tried to use the Maxima plugin several times without any success.
I was able to do the setup as shown here: https://en.smath.com/forum/yaf_postst2078_Maxima-Plugin.aspx
But unfortunately in Smath the Int() function for symbolic integration never works. I'm pretty sure that I'm missing a little part. Can anyone help me please?
Example:
When I do define x I get the following error
And when I do assign something else than a number i get:
#299 Publicado: 13/5/2021 17:05:17
Grupo: Moderator
Hi Guys,
But unfortunately in Smath the Int() function for symbolic integration never works. I'am pretty sure that I'am missing a little part. Can anyone help me please?
Example:
This is because you use numeric optimization (context menu). If you expect symbolic results, use symbolic optimization ("none" also works, it shows the result from Maxima without further processing by SMath).
The error message is correct. The integration variable must be unassigned.
#300 Publicado: 13/5/2021 20:03:57
... but you have missed the best from Generous Smath Community.
1. Always/first plot the integrand.
2. You integrate over a ranged variate.
3. maple is delivered with native Smath.
