Maxima Plugin
Maxima Plugin - Mensajes
#261 Publicado: 13/3/2019 1:34:13
Hi. Can the Maxima plugin beheavior could be changed to agree with SMath (and Mathcad) diff operator, when the variable is defined?:
MaximaDiff.sm (6,87 KiB) descargado 1692 vez(es).
Thanks in advance for your answer.
#262 Publicado: 13/3/2019 6:04:29
Grupo: Moderator
This would require access to the unevaluated (non-preprocessed) verbatim expression from within the plugin. I don't know if that is currently possible. Same problem applies for definite integrals for numeric evaluation. I could take over numeric quadrature as well if I had access to the unevaluated expression.
Perhaps our other developers have a quick anwer?
#263 Publicado: 13/3/2019 7:01:44
Hi Martin. Clean() seems to have this kind of access.
#264 Publicado: 13/3/2019 9:54:01
Grupo: Moderator
Clear() is defined in the Special functions plugin, which is closed source and probably isn't restricted to the third party plugin API.
The Maxima plugin has already survived several API changes, sometimes Andrey made adjustments even to third party plugins immediately, sometimes major re-work is required and update delays result from that. Unfortunately, I probably will only get up and running again with Visual Studio in summer. There is quite a todo list for the maxima plugin.
Maxima has it's own mechanism for suppressing evaluation/simplification, the so called "noun" property (inactive expression). I filed support for this in the plugin as request SS-3478
#265 Publicado: 13/3/2019 11:08:19
Hi Martin. I see the request SS-3478. But I guess that this isn't related with the noun Maxima's property (x::uneval in maple, and Hold[] in Mathematica. Actually I ask some time ago something like this related with derivatives of cool prop package).
I guess that defining
bool IPluginLowLevelEvaluation.ExpressionEvaluation(Term root, Term[][] args, ref Store context, ref Term[] result)
where the difference with normal call is ref Store context, and then
termVar = SMath.Math.Computation.Preprocessing(termVar, ref context);
you can handle the case where an argument is defined, catching the variable name, and trying to determine if it is defined or not.
Actually I paste both of them from Maxima plugin source code. (But the second is commented).
frapuano 13/3/2019 11:54:00
#266 Publicado: 13/3/2019 23:47:19
That's interesting, Alvaro.
My understanding is that the underlying equations are IAPWS, to be tracable.
As implemented in Smath just a cluster fuck. OK, I don't need, using WASP
from Katmar. Under the hood, those functions are monkey business. I say that
because I coded those animals from personal transmission from Bernhard S.
I coded in VB. ALL OK, coded nearly all in Mathcad OK.
About your point of getting the derivative in Smath: not possible.
Not possible unless CoolProp re-coded from A ...Z.
In Smath CoolProp, you just get the interpolated value.
Most probably, those properties are respective data sets, interpolated.
IAPWS are a soup of polynomials. Correctly implemented, you will have
them on plot and derivatives.
I believe this package is the one from Valery at the time of his
web Mathcad calculator.
If interested, can check if still on my MCD 11.
I have most of IAPWS in Smath otherwise approximated, hyper accurate !
Cheers Alvaro ... Jean
PS: WASP from Katmar is not freeware but you have unlimited sessions
of 3 minutes [originally it was 10 minutes].
#267 Publicado: 15/3/2019 2:32:48
Hi. There are some issue here:
maxima_laplace.sm (5,72 KiB) descargado 1745 vez(es).
Martin Kraska 15/3/2019 6:41:00
#268 Publicado: 15/3/2019 6:40:13
Grupo: Moderator
The problem seems to be the pre-mature execution of at() on SMath side. You see that if you switch off the Custom Functions plugin, then the answer is correctly displayed. Thus it isn't a translation issue. It would be desirable to keep the unevaluated response at least if optimization is set to "none".
I need to see if the Maxima plugin can do anything about it or even is the culprit.
Thank you for pointing this out. Filed as SS-4597.
Alvaro 15/3/2019 7:03:00
#269 Publicado: 15/3/2019 7:20:07
Hi Martin. Thanks. Here, exp instead e^ seems to avoid this issue.
Implementation of the Laplace method solving a system of odes with Maxima laplace and ilt transforms, and it's comparative with numerical solution.
Laplace_Maxima.sm (55,37 KiB) descargado 1709 vez(es).
Laplace_Maxima.pdf (128,39 KiB) descargado 1340 vez(es).
Martin Kraska 15/3/2019 11:17:00
#270 Publicado: 15/3/2019 9:45:21
Same as before, but with a system without a close form for the inverse laplace.
Laplace_Maxima2.sm (56,2 KiB) descargado 1666 vez(es).
Laplace_Maxima2.pdf (160,95 KiB) descargado 1178 vez(es).
#271 Publicado: 15/3/2019 9:49:57
Here, exp(x) instead e^ seems to avoid this issue.
As I mentioned this to Reg few days ago, then spot checked in Smath.
No difference was observed on the 15 D results. In Mathcad, yes e^
is less accurate than exp(x) that runs the Win built-in 21 D of which
the kernel retains 17 D and displays 15 by convention.
In other words, Maxima does not recognize e^ as the scalar exp(x).
#272 Publicado: 15/3/2019 11:16:25
Grupo: Moderator
Confirmed. Thank you, filed as SS-4598
#273 Publicado: 15/3/2019 11:19:34
Remember Alvaro, we had some exchange on that Mathsoft Collaboratory.
ODE_Laplace Read First.sm (27,41 KiB) descargado 1706 vez(es).
ODE_Laplace 1rst [Type 1].sm (24,7 KiB) descargado 1569 vez(es).
ODE_Laplace 1rst [Type 2].sm (22,5 KiB) descargado 1551 vez(es).
ODE_Laplace 2nd [Type 3].sm (33,53 KiB) descargado 1507 vez(es).
Created SS 5346 ... OK SS 6179
#274 Publicado: 15/3/2019 15:46:12
Hi Jean.
I remember that.
#275 Publicado: 16/3/2019 18:22:37
Hi Jean.
I remember that.
Try that one with the forcing q(t):= t^0.5 and q(t):= ln(t)
ln(t) expands in term of Ei(,) exponential integral.
How is Maxima will react ?
ODE_Laplace 2nd [Type 3 Dirac Integral].sm (27,8 KiB) descargado 1576 vez(es).
#276 Publicado: 16/3/2019 20:35:25
Hi Jean. Maxima can't find a close symbolic solution, only find the laplace transform. But this example shows how powerful is the Oscar' routine for inverting numerically laplace transforms. RKFixed and RKAdapt fails and, as you point, only the uni specialized solver dn_GearsBDF seems to solve the equation.
Laplace_Maxima6.pdf (94,68 KiB) descargado 1043 vez(es).
Laplace_Maxima6.sm (64,9 KiB) descargado 1697 vez(es).
#277 Publicado: 16/3/2019 23:49:28
Hi. This is my attemp to solve a linear equation with polynomial coefficients by laplace method with Maxima. Even don't works, give a solution very close to the numerical RK solver, but I can't see what I'm doing wrong. Any help is welcomed.
Laplace_Maxima5.sm (99,5 KiB) descargado 1718 vez(es).
#278 Publicado: 18/3/2019 15:41:27
Can't help Alvaro.
I don't have Maxima. Just posted last minute Oscar InvLaplace.
Don't forget Frobenius for some of those kind variable coefficients.
Works fine Smath, with coefficients helper solve.
Buenos dias Amigo !
#279 Publicado: 24/3/2020 10:48:21
netsonicyxf
netsonicyxf
2 me gusta en 79 mensajes.
I have a portable version of Smath 0.99.7251. The Maxima is under D:\Program Files\Math Tools\SMath Studio\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\1.98.7100.23756\
I put the above path into insert->settings, but it show "Cannot find maxima.bat"
#280 Publicado: 24/3/2020 10:52:54
Grupo: Moderator
Did you install Maxima? If not, follow the link in my signature and see the instructions for installing and configuring Maxima. The plugin just provides the interface.
