Maxima Plugin
Maxima Plugin - Mensajes
#321 Publicado: 20/6/2025 22:17:29
Grupo: Moderator
Draw2D() works.
Draw3D() also works.
Editado 20/6/2025 22:18:20
A 4 usuarios les gustó este mensaje
sergio 21/6/2025 8:21:05, NDTM Amarasekera 22/6/2025 8:35:56, Martin Kraska 21/6/2025 9:52:50, Alvaro 21/6/2025 5:34:52
#322 Publicado: 21/6/2025 9:51:42
Grupo: Moderator
Actually, user fakemoses has fixed the Linux path issues in January 2024 (as can be seen in the history in the code repository). At that time there were still issues with the server side compilation of the plugin (the version from the extension manager didn't work, the local version of fakemoses worked). This seems to be fixed now from SMath side.
Thus, I encourage the Linuxing SMathers to give it a try.
A 6 usuarios les gustó este mensaje
Alvaro 21/6/2025 17:34:29, Davide Carpi 21/6/2025 10:25:17, overlord 21/6/2025 11:54:21, sergio 21/6/2025 15:03:53, Andrey Ivashov 21/6/2025 20:54:18, NDTM Amarasekera 22/6/2025 8:35:44
#323 Publicado: 28/8/2025 18:57:43
Grupo: Moderator
This doesn't work, yet it should.
When I debugged it, obviously something is wrong with syntax.
When I corrected it, it could calculate finally.
Otherwise, this equations can't be solved with smath-maxima.
#324 Publicado: 28/8/2025 19:37:07
Grupo: Moderator
according to the Maxima reference to_poly_solve wants lists or sets as arguments, not matrices.
overlord 28/8/2025 19:44:03
#325 Publicado: 28/8/2025 19:47:08
Grupo: Moderator
I thought it need matrices since all maxima Solve() examples in Reference Book are with matrix.
Thanks
Any opinion how to get rid of that union()?
Editado 28/8/2025 19:49:17
#326 Publicado: 28/8/2025 19:57:08
Grupo: Moderator
Solve is a special case, because it is not a direct call to Maxima's function solve() but a lot of work has been done to make it more forgivable in the input format, just like FindRoot(), there you can feed matrices or lists and I would not be surprised if also line() would work.
Also, solve() returns it result as a nested list of lists if there is more than one solution. Nested lists don't survive in SMath processing, so we had to replace the outer list by a matrix (row vector, for better optics).
This all is not done if you use direct calls via the maxima function. The to_poly_function obviously uses the union() expression as wrapping construct for multiple solutions, which should be safe. Yet, you have to find out yourself, how to access the individual arguments of union() to access individual solutions. The arg() function does the job,
Editado 28/8/2025 19:59:06
Oscar Campo 29/8/2025 9:39:23, francesco rapuano 29/8/2025 11:01:38, overlord 29/8/2025 14:49:52
#327 Publicado: 25/10/2026 20:38:36
Grupo: Moderator
I asked Claude to try running SMath with Maxima in it's sandbox. The steps to get it running could apply to any other Ubuntu Linux: https://github.com/fakemoses/MaximaPlugin/wiki/Maxima-Plugin-under-Linux
Mostrar spoiler
usamakhan 26/10/2026 14:51:01, Davide Carpi 27/10/2026 8:09:33
#328 Publicado: 27/10/2026 0:07:42
usamakhan
usamakhan
7 me gusta en 97 mensajes.
Mostrar spoiler
Tested Under Ubuntu Noble with SMath Mono release with Maxima v5.49 it works
#329 Publicado: 29/10/2026 9:17:53
Grupo: Moderator
Maxima under Linux works for over a year.
I didn't create a bat file or modify xml config.
I just works for me. Am I missing something here?
