Hyperlink Region
Hyperlink Region - Add hyperlinks in SMath Studio worksheets/SMath Viewer - Mensajes
#1 Publicado: 27/7/2013 7:08:26
Grupo: Moderator
Hi all,
Here there is a plugin to add hyperlinks in SMath Studio worksheets and SMath Viewer applications.
Plugin UI languages: English Deutsch Italiano Русский Español
PLEASE REPORT IN THIS TOPIC ANY ISSUE.
  • requirements: SMath Studio 0.96.5146 Nigthly build or later, .Net Framework 2.0;
  • installation: download the plugin from the gallery;
  • documentation: download and unzip the attached archive;
  • sources: if you want to see the plugin sources look in the SVN repository;
  • languages: if you want to have a new UI language look into the documentation's Language folder
HyperlinkRegion_docs.7z (45,84 KiB) descargado 1281 vez(es).
A 6 usuarios les gustó este mensaje
IVR 27/7/2013 9:28:00, Вячеслав Мезенцев 1/8/2013 8:56:00, Oscar Campo 29/7/2013 17:06:00, Martin Kraska 27/7/2013 10:34:00, Andrey Ivashov 31/7/2013 19:42:00, ioan92 1/8/2013 2:48:00
#2 Publicado: 27/7/2013 10:38:45
Grupo: Moderator
That would be highly welcome. In the help system, there is a lot of links which now need to be copied to the adress line in the browser.
Are the links to sm-files supposed to open like the current text regions with href attributes (internal links) or are you going to launch new instances of SMath each time such an internal link is clicked?
#3 Publicado: 27/7/2013 11:43:37
Grupo: Moderator
Hi Martin
Each click open a new istance of the required program.
#4 Publicado: 31/7/2013 18:06:14
Grupo: Moderator
First Beta available through plugin's Gallery.
Documentation and translation sheet in the first post.
Best regards,
Davide
Martin Kraska 1/8/2013 6:19:00, Andrey Ivashov 31/7/2013 19:42:00
#5 Publicado: 31/7/2013 19:41:32
Grupo: Super Administrator
Absolutely great! Thank you for such a wonderful plug-in!
P.S.: I love these icons and common approach you use.
P.P.S.: If you found any limitations in SS interfaces, just let me know.
Davide Carpi 1/8/2013 6:20:00
#6 Publicado: 1/8/2013 6:20:12
Grupo: Moderator
Thank you for your program Andrey
Don't worry, I'll do it :d
#7 Publicado: 1/8/2013 7:52:20
Grupo: Moderator
SMath crashes if a hyperlink region is copied by Ctrl-drag.
#8 Publicado: 1/8/2013 9:33:13
Grupo: Moderator
Fixed, test the update...
Best regards,
Davide
Martin Kraska 2/8/2013 1:25:00
#9 Publicado: 2/8/2013 1:24:24
Grupo: Moderator
Works fine, thanks a lot.
#10 Publicado: 2/8/2013 2:34:35
Grupo: Moderator
I am trying to build links to the plugin installation directories in the documentation.
Under windows, the %APPDATA% and the SettingsDirectory() approach work, but how is that under linux? Could the linuxers in the community please test the attached sheet? It contains links to the install directory of the 3D Plot plugin by uni.
@Andrey: The nice feature of being able to paste target strings to the hyperlink placeholder prevents me from pasting the target expression involving SettingsDirectory() directly to the placeholder in the link region. This rises the question, why there is special treatment for string constants in math expressions at all.
Hyperlink.sm (3,16 KiB) descargado 1808 vez(es).
#11 Publicado: 2/8/2013 7:05:07
Grupo: Moderator
I've not yet tested the plugin under linux, I don't know...
I suppose that's possible for texts that contains characters not available for the variable names (such spaces or slashes and backslashes), when you paste something in a placeholder; for the canvas someone may would paste text as text, so a "paste as" would be needed (or a "post-paste context menu item" like in MS word)
#12 Publicado: 2/8/2013 17:51:25
Grupo: Moderator
UPDATED
- Support for SMath Viewer
best regards,
Davide
#13 Publicado: 3/8/2013 17:34:13
Grupo: Moderator
The hyperlink region does not respond immediately to font size changes. You need to close and re-open the file in order to get the desired effect.
Normally, I try to avoid any font changes. In the given case, I tried to build a table containing links which were supposed to fit in a single grid spacing.
Plugin index.sm (23,15 KiB) descargado 1817 vez(es).
#14 Publicado: 3/8/2013 18:00:43
Grupo: Moderator
I know, is an issue of CustomRegions (2D plot, XY Region, etc...)
I've not opened a specific topic, but is already mentioned here (1st image, "original" -> appearance font-size different from real font-size)
best regards,
Davide
#15 Publicado: 9/8/2013 18:35:53
Grupo: Moderator
SMath crashes when I try to edit the input expression of a hyperlink.
I write concat with three arguments, fill in the first and the last. As soon as I want to type to the second placeholder, the crash occures.
#16 Publicado: 9/8/2013 19:07:15
Grupo: Moderator
Fixed, please test the update
best regards,
Davide
Martin Kraska 9/8/2013 19:34:00
#17 Publicado: 9/8/2013 19:35:26
Grupo: Moderator
That was fast... Thanks a lot.
#18 Publicado: 9/8/2013 20:02:03
Grupo: Moderator
You're welcome; I've already noticed the bug working to another plugin
#19 Publicado: 10/8/2013 5:56:30
Grupo: Moderator
When multiple hyperlinks are selected, the custom context menu action "Show link target" is applied only to one region. The other (system) actions can be applied to all selected regions at once.
#20 Publicado: 10/8/2013 6:11:22
Grupo: Moderator
It is a CustomRegion bug, I've reported this behavior to Andrey some day ago
