Hyperlink Region
Hyperlink Region - Add hyperlinks in SMath Studio worksheets/SMath Viewer - Mensajes
#21 Publicado: 23/8/2013 5:54:57
Grupo: Moderator
UPDATED
- command-line options
syntax: 'ProcessToStart'[space]Flags
[edit] - Graphical adjustements
Martin Kraska 23/8/2013 10:19:00
#22 Publicado: 23/8/2013 10:27:19
Grupo: Moderator
Thanks for the fast reaction. Hyperlink is simply great. I find myself launching applications using
Ctrl-H "command +Click
Davide Carpi 23/8/2013 17:13:00
#23 Publicado: 26/8/2013 14:14:20
Grupo: Moderator
UPDATED
Just to complete the early introduced feature
- converter on paste accept command-line strings (input string: "ProcessToStart"[space]Flags)
so when you paste in the placeholder something like:
"C:\Windows\system32\rundll32" sysdm.cpl,EditEnvironmentVariables
this will become:
"'C:\Windows\system32\rundll32' sysdm.cpl,EditEnvironmentVariables"
best regards,
Davide
#24 Publicado: 28/8/2013 3:18:31
Grupo: Moderator
Strange bug: If you copy a Hyperlink region with description using Ctrl-Drag, then both original and copy seem to use the same data. If you edit the copy, the original changes as well (also the cursor is shown there).
Playing around with empty/nonempty or visible/nonvisible description prior to copying shows other glitches like frozen box size in the copy description. That might be secondary symptoms of the data handling problem.
If you copy using Ctrl-C Ctrl-V everyting is fine.
#25 Publicado: 28/8/2013 4:04:39
Grupo: Moderator
thank you, was my fault. Plugin updated.
Martin Kraska 28/8/2013 4:17:00
#26 Publicado: 11/9/2013 14:51:48
sublim21
sublim21
3 me gusta en 36 mensajes.
Just found out about this plugin.
Thanks for the work man.
Just a few quick questions,
lets say i wanted to open up a file with a specific program, what would i type into the hyperlink?
for example, lets say i wanted to open up
song.mp3
with the executable
C:\foobar\foobar.exe
#27 Publicado: 11/9/2013 15:13:36
Grupo: Moderator
song.mp3
with the executable
You might try the approach shown in post23.
Use "'C:\foobar\foobar.exe' song.mp3". It is essential to quote the executable path with ', otherwise windows takes the space as part of the prog name.
#28 Publicado: 11/9/2013 17:50:46
Grupo: Moderator
Exactly
with foobar, if your song contains some spaces use wildcards (*) instead of spaces (f.e. this doesn't work in vlc; I'll think to another approach or another solution to fix this - maybe a double single quotation to have a double quotation or a context menu dialog...)
regards,
Davide
#29 Publicado: 12/9/2013 12:32:18
sublim21
sublim21
totally missed the apostrophes. Thanks for the update.
Amazing plugin websurfer.
#30 Publicado: 6/10/2013 20:09:31
Grupo: Moderator
UPDATED
- Flags input moved from the placeholder to a dedicated context menu item.
This solve double quotes issues involving flags and SMath strings.
- PASTE feature works also with the new input way.
(TEMPORARY feature) To update worksheets containing the old syntax ("'process' flags"):
- open the worksheet
- save the worksheet
- close and open again the worksheet
- delete all except the process name from the input placeholder
regards
Davide
IVR 7/10/2013 8:57:00
#31 Publicado: 8/10/2013 11:57:30
Grupo: Moderator
UPDATED
- Fixed critical bug on exceptions' propagation.
#32 Publicado: 2/2/2014 9:31:50
Grupo: Moderator
UPDATED
- SMath Studio 0.96.5146 required;
- restored red background when the region is disabled;
- click on resize markers now doesn't trigger the link.
best regards,
Davide
#33 Publicado: 2/2/2014 10:02:47
Grupo: Super Administrator
Thank you!
Davide Carpi 2/2/2014 10:09:00
#34 Publicado: 4/2/2014 6:48:12
dyleks
dyleks
0 me gusta en 4 mensajes.
I am using it with version 0.96.5146 but generation
of executable version (viewer) doesn't work for me.
Is that known issue ?
#35 Publicado: 4/2/2014 7:08:28
Grupo: Moderator
Hello, I can't reproduce the issue... could you attach a file that doesn't work for you?
#36 Publicado: 4/2/2014 8:10:27
dyleks
dyleks
The issue is solved.
After SMath was restarted it works.
Sorry for bothering you.
#37 Publicado: 12/2/2014 19:14:21
Grupo: Moderator
UPDATED
- Paste as SMath string temporary disabled (this let you paste strings on the canvas freely)
#38 Publicado: 7/8/2014 19:13:00
ziopaper
ziopaper
1 me gusta en 13 mensajes.
Hi guys,
not sure if it is my issue only, but everything I paste becomes an hyperlink, formulas also.
The way I am working now it starting a dummy formula, paste what I need and then delete the rest. Am I missing something?
I tried to find a reference to this in the forum but did not succeed. I apologize if the answer is already out there.
thanks
#39 Publicado: 8/8/2014 8:34:49
Grupo: Moderator
You're right, the cause is a known bug of the clipboard manager (SS-200). I've accidentally re-enabled the feature in some silent update related to API changes.
PLUGIN UPDATED
- Paste as SMath string temporary disabled.
edit not a SMath bug, just a misinterpreted feature.
sergio 8/8/2014 13:47:00
#40 Publicado: 8/8/2014 12:26:19
ziopaper
ziopaper
ok, thanks!
