MathRegion Critical Error on DEL key action
MathRegion Critical Error on DEL key action - Mensajes
#1 Publicado: 13/1/2022 14:39:53
Igor Skarine
Igor Skarine
14 me gusta en 97 mensajes.
Eventually I have caught a bug that bothered me in a few latest versions of Smath.
critical_bug.sm (3,85 KiB) descargado 1690 vez(es).
Try to delete the first number "4" in front of the ratio.
Step 1: Select it with the cursor.
Mostrar spoiler
Step 2: Press "Del", the "4" turns into a black square.
Mostrar spoiler
Step 3: Press "Del" once again. SM pops on "Critical error".
Mostrar spoiler
Davide Carpi 14/1/2022 4:08:00
#2 Publicado: 13/1/2022 18:06:39
Igor Skarine
Igor Skarine
Jean,
It can't be doctored, it is not a calculation issue.
Smath Studio crashes at the moment you push "DEL" key to delete this number "4" or whatever else there.
#3 Publicado: 13/1/2022 19:31:57
churichuro
churichuro
29 me gusta en 79 mensajes.
I confirm the error
#4 Publicado: 13/1/2022 22:05:45
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Confirmed. I also came across it, but I didn't investigate it. SMath Studio 0.99.7921.69.
#5 Publicado: 14/1/2022 1:54:58
Grupo: Moderator
confirmed under linux.
same behavior.
#6 Publicado: 14/1/2022 5:59:07
Grupo: Moderator
Thank you, confirmed
System.IndexOutOfRangeException: Index out of matrix bounds.
   in SMath.Controls.MathPainter.PrepareForPaint(MathRegion region, PaintContext ctx, Term[] input, MathAnswer answer, Term[] units, Boolean inputDataVisibility, Int32 currentTermIdx, FontInfo font, Boolean focused, Single& middleLine, Single& baseLine)
   in SMath.Controls.MathRegion.(IGraphics , PaintEventOptions )
   in SMath.Controls.MathRegion.OnCommandSend(String value)
   in SMath.Controls.WorksheetEditor.(RegionBase , String )
   in SMath.Controls.WorksheetEditor.InsertManager(String value)
   in SMath.Controls.Worksheet.Insert(String value)
   in SMath.Controls.WorksheetEditor.KeyDown(KeyEventOptions e)
   in SMath.UI.Accessories.DesktopWorksheet.OnKeyDown(KeyEventArgs e)
   in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
   in System.Windows.Forms.Control.WmKeyChar(Message& m)
   in System.Windows.Forms.Control.WndProc(Message& m)
   in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
#7 Publicado: 14/1/2022 10:59:14
Grupo: Moderator
... end of it !
It didn't surprise me that Jean couldn't understand what the bug is.
Alvaro 14/1/2022 12:39:00
#8 Publicado: 14/1/2022 11:32:56
Grupo: Moderator
Jean, what you're trying to do here is destructive. You prevent users from helping developers improve the program, that is, you bring harm. You don't have to do that. This is not good.
A 6 usuarios les gustó este mensaje
Oscar Campo 17/5/2022 12:41:00, churichuro 14/1/2022 14:38:00, sergio 14/1/2022 15:05:00, overlord 14/1/2022 11:57:00, Alvaro 14/1/2022 12:39:00, fedeghi 14/1/2022 16:43:00
#9 Publicado: 14/1/2022 14:17:41
Grupo: Moderator
Jean, in the exUSSR there was such a norm as forced rest. People who worked hard were forced to rest in a sanatorium. And their leaders, who allowed this, were punished. I think you need to go to a sanatorium and temporarily stop working here. I don't want to be punished and I can give you a rest.
A 4 usuarios les gustó este mensaje
NDTM Amarasekera 14/1/2022 22:41:00, fedeghi 14/1/2022 16:43:00, overlord 14/1/2022 14:23:00, Alvaro 14/1/2022 15:55:00
#10 Publicado: 14/1/2022 16:04:25
Grupo: Moderator
Basically up to SS 6179, Smath is an equation editor
working similar to Mathcad 11 and earlier, including program.
AFAIK, an option for script style [typical Kalkulator ...]
will manage the critical error demo bug.
Is it possible to combine both: part script style & equation editor ?
As well as accommodate both styles in program ?
And yet another useless not related post again.
Unbelievable. Wow, just wow.
Such ignorance, such obstinate, such thick head...
I am out of speech right now.
fedeghi 14/1/2022 16:45:00, NDTM Amarasekera 14/1/2022 22:42:00, Oscar Campo 17/5/2022 12:40:00
#11 Publicado: 16/5/2022 12:06:43
Igor Skarine
Igor Skarine
Unfortunately,
The "Critical Error on Del key action" was not fixed yet in the latest stable version.
Try to delete "g" by using DEL key.
oldbug.sm (2,25 KiB) descargado 1678 vez(es).
#12 Publicado: 17/5/2022 20:38:34
Grupo: Super Administrator
Ok, will check asap.
Davide Carpi 18/5/2022 4:42:00
#13 Publicado: 16/6/2022 20:29:35
⚜ Kenny Lemens, P.E. ᵂᴵ
85 me gusta en 181 mensajes.
Greetings!
I can also confirm the existence of this issue ( "v0.99.7921.69" ). Upon investigation, I have (2) items:
  1) The program does not actually 'crash', the program is still running. Thus: you can recover from this bug without losing all your work!
      a) To recover from this error:
            1) On the "⨂ Unhandled exception has occurred ... Index was outside the bounds of the array" popup error message, Click on the button: 「Continue」
            2) 'UNDO' your last action, either via the menu bar: 「Edit」 -> 「↻ Undo」 or via keypress 「Ctrl」 + 「Z」
            3) Repeat steps #1 and #2 until you achieve a successful 'undo'.
  2) The elements of this error seem to require a grouping operator (e.g., Absolute Value, Parenthesis, Determinant, Square Root, Matrix) that is paired with a fraction/division operation, prepend this with a multiplication statement and you can duplicate the error. See screen capture below:
Below are a few statements I compiled; performing the double-delete on the integer '6' will throw the same error:
-Kenny Lemens, P.E.
#14 Publicado: 23/6/2022 11:31:02
Greetings,
I found another configuration that can trigger this error; if you declare/evaluate a variable, and then try to multiply that entire set: you get a syntax error. Now if you attempt to correct the statement by using the [DEL] to remove the evaluation, the error gets thrown (as shown below):
The work around would be to use the [Backspace] to delete/correct the equation, or to copy/paste the terms into a new statement without syntax errors.
-Kenny Lemens, P.E.
Davide Carpi 23/6/2022 14:21:00
#15 Publicado: 22/7/2022 17:33:42
Finally fixed in version 1.0.8238.
⚜ Kenny Lemens, P.E. ᵂᴵ 22/7/2022 17:41:00, João Felipe Seráfico Melo 22/7/2022 18:02:00, sergio 23/7/2022 5:37:00
#16 Publicado: 13/4/2023 10:40:14
salmawisoky
salmawisoky
0 me gusta en 2 mensajes.
Greetings,
I found another configuration that can trigger this error; if you declare/evaluate a variable, and then try to multiply that entire set: you get a syntax error. Now if you attempt to correct the Candy Crush statement by using the [DEL] to remove the evaluation, the error gets thrown (as shown below):
-Kenny Lemens, P.E.
I tried that .... still get the error
