How can I use not a for but a while cycle?
How can I use not a for but a while cycle? - Messages
#1 Posted: 2024/2/9 21:27:16
Valery Ochkov
Valery Ochkov
66 likes in 690 posts.
See please the attached file.Newton.sm (23.6 KiB) downloaded 1415 time(s).
#2 Posted: 2024/2/9 23:38:00
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 180 posts.
Greetings,
Instead of using for(3); you can use for(4):
for ▮, ▮, ▮
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
   k:=2*i
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
Valery Ochkov 2024/2/10 14:37:00
#3 Posted: 2024/2/10 14:38:31
Valery Ochkov
Valery Ochkov
Thanks
But see "???" in the attach
Newton-for-1-2-3-4.sm (26.47 KiB) downloaded 1374 time(s).
#4 Posted: 2024/2/10 18:38:42
StvMath
StvMath
44 likes and 1 dislikes in 71 posts.
Here's a "while" version
Newton-for-1-2-3-4_b.sm (18.98 KiB) downloaded 1407 time(s).
Valery Ochkov 2024/2/10 19:44:00
#5 Posted: 2024/2/11 01:58:11
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (52.75 KiB) downloaded 1300 time(s).
Valery Ochkov 2024/2/11 02:13:00
#6 Posted: 2024/2/11 02:53:28
Valery Ochkov
Valery Ochkov
Roots vs Newton
#7 Posted: 2024/2/11 07:55:50
oots vs Newton
No interest vs the codes
#8 Posted: 2024/2/11 13:41:06
Valery Ochkov
Valery Ochkov
Roots vs Newton
https://www.mdpi.com/2227-7390/10/19/3413
#9 Posted: 2024/2/11 21:59:12
roots solves Matrix.
Worksheet33.sm (6.96 KiB) downloaded 1390 time(s).
#10 Posted: 2024/2/13 06:19:59
1,355 likes in 2,271 posts.
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (16.22 KiB) downloaded 1470 time(s).
Alvaro 2024/2/29 12:13:00
