Drop down options
Drop down options - Select variable based on the value of another variable - Messages
#1 Posted: 2020/4/30 05:32:46
Praveen P K
Praveen P K
0 likes in 2 posts.
Hi I am new to Smath
I want to select few variables. eg
If P=1, then X = 1, Y=2 & Z=3
If P=2, then X = 4, Y=1 & Z=7
If P=3, then X = 3, Y=2 & Z=1
I want to use X, Y & Z values based on the selected value of P
Thanks in advance
#2 Posted: 2020/4/30 08:33:57
#3 Posted: 2020/4/30 08:36:30
Praveen P K
Praveen P K
0 likes in 2 posts.
Thanks Jean
I will try this one
#4 Posted: 2020/4/30 08:42:33
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Using "cases" function.
cases_ex.sm (89.06 KiB) downloaded 574 time(s).
Davide Carpi 2020/5/1 08:59:00
#5 Posted: 2020/4/30 09:26:22
I will try this one
Page1 if_oterwise.sm (4.7 KiB) downloaded 660 time(s).
Davide Carpi 2020/5/1 09:00:00
#6 Posted: 2020/4/30 11:25:14
haweHofmann
haweHofmann
3 likes in 32 posts.
If you want to use the variable names X,Y,Z
a simple
data:mat(1,4,3,2,1,2,3,7,1,3,3)
mat(X,Y,Z,3,1):col(data,p)
will do the job.
you can also use a vector XYZ
XYZ:el(data,range(1,3),p)
and its components i=1..3
el(XYZ,i)
copy code to sheet
#7 Posted: 2020/4/30 12:41:19
Generalize demo. No sweat to capture [X,Y,Z] from n*m matrix.
Page5 Generalize.sm (5.88 KiB) downloaded 650 time(s).
