1 Pages (9 items)
Contour Integral Dummy Style - Contour Integral Dummy Style - Messages
Can't manage this otherwise than shitting bricks !
Solution is welcomed ... Thanks
Done otherwise to rescue the Document.
Inst_PID Discrete Schema EXAMPLE_6 Failed.sm (36.61 KiB) downloaded 622 time(s).
WroteCan't manage this otherwise than shitting bricks !
In order to pass functions as inputs to other functions you need to declare it as such and pass a "dummy" variable. See following.
There is still a problem in that it is not evaluating properly, I believe.
Inst_PID Discrete Schema EXAMPLE_6_Partlyfixed..sm (44.75 KiB) downloaded 586 time(s).
frapuano 2018/12/10 16:55:00
fixed
Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm (46.19 KiB) downloaded 667 time(s).
![2018-12-11 00_34_33-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm].png](/zh-Hans-CN/files/Download/xLgXx6/2018-12-11-00_34_33-SMath-Studio---[Inst_PID-Discrete-Schema-EXAMPLE_6---fixed.sm].png)
P.S. To obtain similar results, change the integration accuracy to something higher than 100
![2018-12-11 00_53_52-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm_].png](/zh-Hans-CN/files/Download/pwH7T5/2018-12-11-00_53_52-SMath-Studio---[Inst_PID-Discrete-Schema-EXAMPLE_6---fixed.sm_].png)
- removed answer requested for first argument of the last system;
- used f(number_of_arguments) function of function argument (more elegant, point out that the variable name doesn't matter);
Arie 2018/12/10 20:37:00
Wrotefixed
Dumb question maybe, but how do you get the '#' to show up in the H(#) function call?
WroteDumb question maybe, but how do you get the '#' to show up in the H(#) function call?
As simple as that: x(n,X(▄)) ... simply the native dummy argument
big square imitation Alt220 ... try it.
Thanks all you Doctors ! Just refreshing that huge collection
of PID examples, coming soon.
CTRL+K then #
:d
Wrotebig square imitation Alt220
another option, yes
Hi. This is the setup for use inverse laplace transform for numerically evaluate the response for a system in z domain.
pid_controler z.sm (50 KiB) downloaded 662 time(s).
frapuano 2018/12/13 19:41:00
1 Pages (9 items)
