special functions addin
special functions addin - special functions - Messages
#1 Posted: 2019/3/20 17:00:32
The Cross
The Cross
0 likes in 73 posts.
What does the special functions addin do, and how do you add it to the sheets?
#2 Posted: 2019/3/20 19:51:28
Special functions is too large a word: anything that does something
wrt maths is a special function [Floor, Ceil, round, abs ...]
You can have lot more functions from already developed for purpose.
Gamma(x) 15 D, Si, Ei, Li, Polylog, Polygamma, Dawson, Whittaker,
plenty poly orthogonal, plenty distributions ... Airy CoC
Essential Fourier, Bessel from the f(x) menu
Already quite a few distributions from f(x) menu.
Better than plugin is a collection in work sheet.
that you can call via the command "include".
What's your wish list ...
#3 Posted: 2019/3/20 19:52:25
1,078 likes in 1,749 posts.
Hi Britt. Actually SpecialFunctions isn't an "external" plugin, it was, but not any more. From an old SMath update:
"New functions added to the SpecialFunctions built-in plugin: importData(..), str2num(), num2str(), concat(..), findstr(.), substr(.), substr(..), strrep(..), strlen(), IsString() and error();"
So, it have some useful function, but not the usual math "SpecialFunctions". You can found them at other numerical plugins, like:
https://en.smath.com/forum/yaf_postst1775_AlgLib-3-1x.aspx
https://en.smath.com/forum/yaf_postst1918_DotNumerics.aspx
https://en.smath.com/forum/yaf_postst1965_Cephes-Math-Library.aspx
but this list ins't complete.
#4 Posted: 2019/3/20 20:05:07
1,435 likes in 2,913 posts.
go to insert > functions... and play with the plugins dropdown to see what functions are carried by each plugin, also by Special Functions
#5 Posted: 2019/3/20 21:42:25
Dionysios J. Pantazis
16 likes in 179 posts.
Kinda like this.....
