Roots - intersection points
Roots - intersection points - Trouble with finding intersection points of a line and a parabola using "roots" command. - Messages
#1 Posted: 2023/4/14 16:43:40
SERGIO MARQUES DE SOUZA
0 likes in 5 posts.
Good afternoon everyone.
I'm using the "roots" command, but I'm not getting the two points where the line intersects the parabola. The command gives me only one result and omits the other point. Attached is the file and image of the problem. How can I find both intersection points?
Roots.sm (8.44 KiB) downloaded 735 time(s).
Click to enlarge
#2 Posted: 2023/4/14 17:35:21
As doctored ... Jean
Roots Doctored.sm (9.38 KiB) downloaded 742 time(s).
#3 Posted: 2023/4/14 18:41:21
1,078 likes in 1,749 posts.
Hi Sergio. There are a 3 argument version of roots, where the third is a guess value for the root.
Roots.sm (9.84 KiB) downloaded 765 time(s).
#4 Posted: 2023/4/15 08:54:21
'roots' is essentially based on differentiable function.
Often, in Engineering works you don't have differentiable functions,
Gamma(x), spline fit ... etc.
In those cases, use the X(Φ,a,b,ε) utility.
roots Gamma(x).sm (18.54 KiB) downloaded 741 time(s).
#5 Posted: 2023/4/15 19:31:34
580 likes in 1,348 posts.
Here your solution solved with maple plugin.
No need to enter guess points for this.
Maxima can solve it too, similarly.
PS: MapleCorrect() function can be found here.
Assign() function can be used instead of str2num() + num2str() + strrep().
#6 Posted: 2023/4/15 20:44:04
1,308 likes in 2,221 posts.
My personal favourite way to handle solver results is Davide's at() substitution function.
#7 Posted: 2023/4/16 02:49:20
Hi. This is another way.
Roots.sm (16.66 KiB) downloaded 723 time(s).
#8 Posted: 2023/4/16 09:11:08
Many Smath built-in functions are not differentiable.
diff(▄ ▄) not defined ... Airy example attached.
roots Airy.sm (11.05 KiB) downloaded 712 time(s).
#9 Posted: 2023/4/16 11:22:35
What the heck? Can we use maple keywords if they are written as `function`?
This is so mind-blowing, thanks Razonar.
Alvaro 2023/4/17 17:27:00
#10 Posted: 2023/4/16 18:34:02
#11 Posted: 2023/4/17 01:44:30
I found a Windows laptop.
And tried Maxima plugin Solve().
It can solve easily.
