1 Pages (4 items)
Simple beam analysis, graph - Simple beam analysis, graph - Messages
Hi every one. I have some questions.
Q1) When performing symbolic calculations, I currently have to manually set the optimization to 'numeric' (or 'symbolic'/'none') for each region individually. Is there a way to change the default optimization setting to 'symbolic' or 'none' globally?
Q2) I have created a worksheet for the SFD and BMD of a simple beam, as shown in the image. I am trying to plot these diagrams using the XY Plot component.How can I restrict the x-axis range to display only the interval from 0 to 1?How can I mark the specific point of M_max on the graph?
Thank you for all.
12.SimpleBeam_01.sm (63.68 KiB) downloaded 699 time(s).
Thank you for all.
a. From Edit menu select All, then right-click on any blue region and select None from the optimisation section.
b. Double click on the graph and select the various options on the resulting menu - see attached.
12.SimpleBeam_01b.sm (86.53 KiB) downloaded 739 time(s).
kimkim 2025/12/14 10:31:17
Wrotea. From Edit menu select All, then right-click on any blue region and select None from the optimisation section.
I'm so appreciative of you.
When I draw SDF, BMD,' roots' function is more efficient than 'Solve' function as you wrote!!
Thank you.
1 Pages (4 items)
