AlgLib 3.1x
AlgLib 3.1x - AlgLib Plugin (based on ALGLIB 3.1x) - Messages
#41 Posted: 2018/12/24 07:47:08
1,554 likes in 1,864 posts.
Updated.
2018-12-24_15-42-32.png 2018-12-24_15-43-00.png 2018-12-24_15-43-31.png 2018-12-24_15-43-56.png
alglib.ode.kinetic1.sm (7.78 KiB) downloaded 1594 time(s).
alglib.ode.kinetic2.sm (10.35 KiB) downloaded 1695 time(s).
alglib.ode.kinetic3.sm (10.04 KiB) downloaded 1710 time(s).
alglib.ode.test1.sm (10.46 KiB) downloaded 1676 time(s).
alglib.ode.test2.sm (10.63 KiB) downloaded 1640 time(s).
alglib.ode.Amplitude detector.sm (19.77 KiB) downloaded 1684 time(s).
alglib.ode.kinetic1.pdf (75.29 KiB) downloaded 942 time(s).
alglib.ode.kinetic2.pdf (89.97 KiB) downloaded 893 time(s).
alglib.ode.kinetic3.pdf (83.16 KiB) downloaded 867 time(s).
alglib.ode.test1.pdf (85.24 KiB) downloaded 873 time(s).
alglib.ode.test2.pdf (89.96 KiB) downloaded 896 time(s).
alglib.ode.Amplitude detector.pdf (147.84 KiB) downloaded 922 time(s).
5 users liked this post
bdrunagle 2018/12/24 08:15:00, NDTM Amarasekera 2018/12/24 09:44:00, sergio 2018/12/24 11:04:00, frapuano 2018/12/24 14:22:00, Radovan Omorjan 2018/12/24 14:52:00
#42 Posted: 2018/12/28 14:02:54
Updated. Refactored.
sergio 2018/12/28 16:14:00, frapuano 2018/12/28 19:22:00, NDTM Amarasekera 2018/12/28 22:53:00
#43 Posted: 2019/1/19 16:31:14
Updated. al_nleqsolve(2), al_nleqsolve(3), al_nleqsolve(4) added.
File not found. File not found. File not found.
sergio 2019/1/19 17:38:00, frapuano 2019/1/19 18:11:00, NDTM Amarasekera 2019/1/19 23:45:00
#44 Posted: 2019/1/27 05:23:49
With numeric optimization (for all functions) it works much faster.
Fourier series coefficients.sm (17.54 KiB) downloaded 1561 time(s).
Fourier series coefficients.pdf (138.41 KiB) downloaded 903 time(s).
4 users liked this post
Radovan Omorjan 2019/1/27 08:19:00, Davide Carpi 2019/1/27 07:53:00, frapuano 2019/1/27 08:21:00, NDTM Amarasekera 2019/1/27 09:47:00
#45 Posted: 2019/1/27 10:59:21
Example 2.
Fourier series coefficients.sm (28.46 KiB) downloaded 1689 time(s).
Fourier series coefficients.pdf (170.26 KiB) downloaded 1037 time(s).
sergio 2019/1/27 13:29:00
#46 Posted: 2019/1/27 12:48:06
Otherwise w/o Algib and more Engineering applications
Fourier Budapest39 Smoothing.sm (47.67 KiB) downloaded 1615 time(s).
#47 Posted: 2019/1/27 13:06:32
Fourier-Fejer-Lanczos interesting too.
IrfanView "ResizeResample" zoom up/down in two options
Fourier or Lanczos the best.
Fourier Fejer Lanczos.sm (9.11 KiB) downloaded 1521 time(s).
#48 Posted: 2019/2/18 05:42:17
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Parameterization of implicit functions with al_nleqsolve
Parametrisation.sm (29.88 KiB) downloaded 1604 time(s).
NDTM Amarasekera 2019/2/18 11:46:00, frapuano 2019/2/18 09:08:00, Alvaro 2019/2/18 14:00:00, Вячеслав Мезенцев 2019/2/18 17:50:00
#49 Posted: 2019/2/18 13:59:33
1,123 likes in 1,795 posts.
Hi Ber. Nice technique, easy to implement. You can also make that as a function, and monocolor too.
Parametrisation.sm (25.37 KiB) downloaded 1538 time(s).
Another option could be use y0 as vector, and solve for each element in y0, obtaining res, res1, ..., resn
Fridel Selitsky 2019/2/18 14:44:00
#50 Posted: 2019/2/18 23:53:03
1. SS 6179 does not complain
2. Takes ~ 1 hr to terminate the first function
3. NO plot result [NO complain but NO plot ?]
4. Would be interesting checking if the attached SS 6179
runs in your actual AlgLib 3.1x. If NOT => would be a dramatic bug.
It would indicate that all maths based al_nleqsolve would be scrap.
Contour SOLVE [Electron Solve algo Express].sm (20.66 KiB) downloaded 1341 time(s).
#51 Posted: 2020/11/22 04:47:54
Updated.
Changes:
- source code updated to ALGLIB 3.16.0;
- refactored.
#52 Posted: 2021/2/22 16:06:56
Updated.
Changes:
- source code updated to ALGLIB 3.17.0;
sergio 2021/11/17 12:20:00
#53 Posted: 2021/11/17 11:42:24
SMath Studio compatibility
Plugin updated.
Changes:
- source code updated to ALGLIB 3.18.0;
- al_polyroots() function added.
Fridel Selitsky 2021/11/17 12:18:00, sergio 2021/11/17 12:20:00, Alvaro 2021/11/17 13:00:00, NDTM Amarasekera 2021/11/17 16:44:00
#54 Posted: 2021/12/8 02:43:14
Plugin updated.
Changes:
- al_lspline(), al_pspline() fucntions added;
- some functions now have a reduced number of parameters (input vector lengths are no longer required);
- refactored.
#55 Posted: 2021/12/10 01:36:46
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
sergio 2021/12/10 05:27:00
#56 Posted: 2021/12/20 16:18:35
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
