1 Pages (15 items)
corrupted file - Ioan - Messages
Hi all,
Trying to reopen a file that I wrote and that refused to be closed normaly, I receive this message:
I posted the file here:
file
Is it possible to recover the file ? If yes, how ?
Thanks a lot for any help,
Ioan
NMyMz.zip (454.08 KiB) downloaded 394 time(s).
"Unexpected end of file occured.
The following elements are not closed:
result, math, region, regions. Line 82490, position 12."
file
Ioan
Please attach your file to the forum: http://en.smath.info/forum/yaf_help_index.aspx?faq=attachments
the link to the file points to a hoster which requires login/registration. I won't create a login at a filehoster just to download a single file. You might use dropbox or the smath wiki file management.
The problem might be solved by just closing the xml tags in the file, but I can't try...
If that is the solution than I guess that SMath should be able to propose this approach and apply the fix.
Best regards, Martin
I agree, Ioan please attach the file directly to the forum or use a registration-free hosting service...
The solution is indicated by mkraska and the result is in the attached file
regards,
w3b5urf3r
WrotePlease attach your file to the forum: http://en.smath.info/for...dex.aspx?faq=attachments
WroteThe problem might be solved by just closing the xml tags in the file
regards,
w3b5urf3r
Thanks for your answers,
Many thanks to w3b5urf3r for the recovered file.
Now the original file is attached to my first post.
I still have a problem with this file:
all results are in fractional mode, against my temptatives of changing.
You are welcome
simply change the result optimization from "none" to "numeric"
regards,
w3b5urf3r
Wroteall results are in fractional mode, against my temptatives of changing.
regards,
w3b5urf3r
Thanks again w3b5urf3r.
Best regards to all,
Ioan
Ioan
Hello there,
I have similar problem with my document. I saved file on hard disk but when i reopened it all text below pagebreak stamp disappeared.
Please look at it, help if possible it is important for me.
File with lost data.sm (483.59 KiB) downloaded 1266 time(s).
I don't find anything wrong with your file. It opens fine on my computer with Win 7 and SMath 0.95. You have collapable areas within a collapsable area.
Ed
Hi there,
I have one more corrupt file. This time I can not even open it.
Thanks for every help.
ZELBET_Przebicie_PNB_03264_2002_v1.sm (497.75 KiB) downloaded 1315 time(s).
WroteHi there,
Hi Anonymous,
The recovered file is in the attachments.
@Andrey The issue is in these lines, at the end of the Anonymous original file...
<region id="163" left="0" top="7227" width="326" height="334" color="#000000" bgColor="#ffffff" fontSize="10">
<math error="9">
<input>
<e type="operand">Typ</e>
<e type="operand" style="string">1</e>
<e type="operator" args="2">≡</e>
<e type="operand">A</e>
<e type="operand">b</e>
<e type="operand">2</e>
<e type="operand">d</e>
<e type="operator" args="2">*</e>
<e type="operator" args="2">+</e>
<e type="bracket">(</e>
<e type="operand">1</e>
<e type="operator" args="2">:</e>
<e type="operand">A.2</e>
<e type="operand" style="string">Nie dotyczy</e>
<e type="function" preserve="true" args="4">line</e>
<e type="operand" style="string">2</e>
<e type="operand" style="string">3</e>
<e type="operator" args="2">|</e>
<e type="operand">B</e>
<e type="operator" args="2">-</e>
<e type="operand">H</e>
<e type="operand">h</e>
<e type="operator" args="2"><</e>
<e type="operand">L</e>
<e type="operand">l</e>
<e type="operator" args="2">&</e>
<e type="operand">d.1</e>
<e type="operator" args="2">≥</e>
<e type="operand">d.2</e>
<e type="operand">#</e>
<e type="function" preserve="true" args="5">line</e>
<e type="function" preserve="true" args="2">if</e>
<e type="function" preserve="true" args="4">if</e>
<e type="function" preserve="true" args="3">if</e>
</input>
</math>
</region>
regards,
w3b5urf3r
ZELBET_Przebicie_PNB_03264_2002_v1.sm (492.56 KiB) downloaded 1305 time(s).
Thanks for help w3b5urf3r. It is working now.
Unfortunately I have a similar problem with my file.
After I finished my document it didn't saved somehow and now when I'm trying to open it I just see a grey background
I would be really grateful if someone could help me with it, because it's very important for me.
Best regards,
Ann
Słupy.sm (2.61 MiB) downloaded 16 time(s).
Best regards,
Ann
Hi Ann163,
here there is whatever is recoverable.
I wish you an happy new year,
Davide
Słupy.sm (2.61 MiB) downloaded 22 time(s).
Davide
1 Pages (15 items)
