Beta: SMath Studio 0.99.7219 (07 October 2019)
Beta: SMath Studio 0.99.7219 (07 October 2019) - Messages
#1 Posted: 2019/10/7 12:06:36
1,435 likes in 2,913 posts.
8 users liked this post
Radovan Omorjan 2019/10/7 12:13:00, NDTM Amarasekera 2019/10/7 12:27:00, sergio 2019/10/7 12:46:00, frapuano 2019/10/7 14:52:00, Dionysios J. Pantazis 2019/10/7 15:34:00, Ryan Freund 2019/10/7 17:20:00, Вячеслав Мезенцев 2019/10/7 17:48:00, Arie 2019/10/8 13:12:00
#2 Posted: 2019/10/7 18:05:48
Ryan Freund
Ryan Freund
20 likes in 339 posts.
This is great, thank you.
A few comments:
It would be nice to set the default text. If I change it, it will not remain as the default.
The default font size now changes correctly, however it remains shown as 10 (graphically) in the ribbon.
When using the "show description" feature. The text returns down a line when using " or ' characters.
Edit:
I don't think the font style of "descriptions" can be changed.
#3 Posted: 2019/10/20 13:57:56
580 likes in 1,348 posts.
I use monospace characters in my documents; so I stick with courier new, fixedsys, typewriter fonts. New created description texts in 7219 always have Arial font and it can't be changed. I need to copy and modify a variable from earlier versions which has precreated description text.
And font can be changed to anything with a text editor like notepad.
#4 Posted: 2019/10/22 17:03:52
zackchen
zackchen
0 likes in 11 posts.
I think solve function cant solve with unit,who can help me?
Test about solve.sm (5.89 KiB) downloaded 935 time(s).
#5 Posted: 2019/10/22 18:15:16
manolo
manolo
8 likes in 9 posts.
Try this:
#6 Posted: 2019/10/22 18:19:06
Why not work maths as they exist from the cave man, i.e: unitless ?
#7 Posted: 2019/10/23 06:07:38
116 likes in 332 posts.
You can also use FindRoot from the NonLinearSolvers plugin, well documented, for details, in Martin Kraska guide
#8 Posted: 2019/10/23 13:07:58
#9 Posted: 2019/10/23 16:22:24
1,308 likes in 2,221 posts.
This is the version with the Maxima plugin:
solveunits.sm (7.86 KiB) downloaded 899 time(s).
sergio 2019/10/24 04:23:00
#10 Posted: 2019/10/23 16:35:41
zackchen
zackchen
Try this:
in this way, I need install maple?
#11 Posted: 2019/10/23 16:37:04
zackchen
zackchen
I am try to solve EQ with unit. Thank you too!
#12 Posted: 2019/10/23 16:39:40
zackchen
zackchen
Thank you! this way is very good. But I find another problem.
Test about solve.sm (6.49 KiB) downloaded 945 time(s).
#13 Posted: 2019/10/23 17:10:47
FindRoot performs implicit assignment to x.
Therefore, you have to Clear(x) before you can solve for x again. Just as demonstrated in the Maxima example above. There, the solution is assigned explicitly using Assign() from the Maxima-Plugin
See Interactive Handbook> Function Index> Assign or Solve
#14 Posted: 2019/10/23 18:05:54
zackchen
zackchen
thank you sir. I solve my problem!
#15 Posted: 2019/10/24 08:52:58
I solved my problem !
Read carefully the attached.
Solve Given_Find [System Demo epsilon].sm (25.89 KiB) downloaded 779 time(s).
#16 Posted: 2019/10/24 11:09:03
Read even more carefully the attached.
All in all: Smath solvers has solved all Mathcad 11 great projects.
The bugger in Smath FindRoot is 'ε'
i.e: needed or detrimental [detrimental in attached Butler].
To make it clear, Mathcad Given Find is Mathsoft proprietary.
It has no competition in difficult applications.
Some projects toke weeks, from brain storm collaboration.
Cheers ... Enjoy Butler.
Solve Given_Find [CO2_6179].sm (34.34 KiB) downloaded 804 time(s).
#17 Posted: 2019/10/24 12:48:45
Hello Jean,
It seems something is wrong here. Results seems to be doubtful and I think epsilon is missing as a third argument in FindRoot()
If I add it
Playing with the fourth argument will give
Moreover, roots() will fail
#18 Posted: 2019/10/24 17:54:18
Hello Jean,
Quite right Radovan, many things don't cut the mustard !
1. "roots" fails in your version, but superb in my native SS 6179.
2. "epsilon" deteriorates the solver in this FindRoot application.
3. The system reacts like proportional/commutative wrt reactants.
What matters is the balance [Alkalinity] 0.0000012
sounds pretty good to me ? Should revisit the paper problem,
Reference: Butler, Carbon Dioxide Equilibria, Prob. 2-11, pg 41
#19 Posted: 2019/10/25 09:58:44
I could not retrieve the very original.
Here is something.
https://www.isws.illinois.edu/pubdoc/CR/ISWSCR-171.pdf
