Beta: SMath Studio 0.99.7219 (07 October 2019)
Beta: SMath Studio 0.99.7219 (07 October 2019) - Сообщения
#1 Опубликовано: 07.10.2019 12:06:36
Изменения, входящие в версию 0.99.7219
Улучшения
  • Arial made a default font for Text Region.
Исправления
  • Changing font Familty and font size for several selected Regions fixed;
  • Fixed exception happens on some environments when rendering font names in font selector;
  • Fixed issue related to empty Descriptions on file open;
  • Select All supported inside embedded Regions now.
Разное
  • Worksheet files layout updtaed to be supported by earlier SMath Studio versions;
  • The following functions allows to calculate 0^0 now: sum(4), product(4), eval(1);
  • Situations with unwanted change of font options fixed.
Скачать
SMathStudioDesktop.0_99_7219.Mono.tar.gz (1,4 МиБ) скачан 2595 раз(а).
SMathStudioDesktop.0_99_7219.Setup.msi (2,27 МиБ) скачан 6434 раз(а).
8 пользователям понравился этот пост
Radovan Omorjan 07.10.2019 12:13:00, NDTM Amarasekera 07.10.2019 12:27:00, sergio 07.10.2019 12:46:00, frapuano 07.10.2019 14:52:00, dio pants 07.10.2019 15:34:00, Ryan Freund 07.10.2019 17:20:00, Вячеслав Мезенцев 07.10.2019 17:48:00, Arie 08.10.2019 13:12:00
#2 Опубликовано: 07.10.2019 18:05:48
Ryan Freund
Ryan Freund
This is great, thank you.
A few comments:
It would be nice to set the default text. If I change it, it will not remain as the default.
The default font size now changes correctly, however it remains shown as 10 (graphically) in the ribbon.
When using the "show description" feature. The text returns down a line when using " or ' characters.
Edit:
I don't think the font style of "descriptions" can be changed.
#3 Опубликовано: 20.10.2019 13:57:56
599 сообщений из 1 380 понравились пользователям.
I use monospace characters in my documents; so I stick with courier new, fixedsys, typewriter fonts. New created description texts in 7219 always have Arial font and it can't be changed. I need to copy and modify a variable from earlier versions which has precreated description text.
And font can be changed to anything with a text editor like notepad.
#4 Опубликовано: 22.10.2019 17:03:52
Jacques CHEN
Jacques CHEN
0 сообщений из 11 понравились пользователям.
I think solve function cant solve with unit,who can help me?
Test about solve.sm (5,89 КиБ) скачан 1619 раз(а).
#5 Опубликовано: 22.10.2019 18:15:16
manolo
manolo
8 сообщений из 9 понравились пользователям.
Try this:
#6 Опубликовано: 22.10.2019 18:19:06
Why not work maths as they exist from the cave man, i.e: unitless ?
#7 Опубликовано: 23.10.2019 06:07:38
You can also use FindRoot from the NonLinearSolvers plugin, well documented, for details, in Martin Kraska guide
#8 Опубликовано: 23.10.2019 13:07:58
#9 Опубликовано: 23.10.2019 16:22:24
This is the version with the Maxima plugin:
solveunits.sm (7,86 КиБ) скачан 1607 раз(а).
sergio 24.10.2019 04:23:00
#10 Опубликовано: 23.10.2019 16:35:41
Jacques CHEN
Jacques CHEN
Try this:
in this way, I need install maple?
#11 Опубликовано: 23.10.2019 16:37:04
Jacques CHEN
Jacques CHEN
I am try to solve EQ with unit. Thank you too!
#12 Опубликовано: 23.10.2019 16:39:40
Jacques CHEN
Jacques CHEN
Thank you! this way is very good. But I find another problem.
Test about solve.sm (6,49 КиБ) скачан 1640 раз(а).
#13 Опубликовано: 23.10.2019 17:10:47
FindRoot performs implicit assignment to x.
Therefore, you have to Clear(x) before you can solve for x again. Just as demonstrated in the Maxima example above. There, the solution is assigned explicitly using Assign() from the Maxima-Plugin
See Interactive Handbook> Function Index> Assign or Solve
#14 Опубликовано: 23.10.2019 18:05:54
Jacques CHEN
Jacques CHEN
thank you sir. I solve my problem!
#15 Опубликовано: 24.10.2019 08:52:58
I solved my problem !
Read carefully the attached.
Solve Given_Find [System Demo epsilon].sm (25,89 КиБ) скачан 1435 раз(а).
#16 Опубликовано: 24.10.2019 11:09:03
Read even more carefully the attached.
All in all: Smath solvers has solved all Mathcad 11 great projects.
The bugger in Smath FindRoot is 'ε'
i.e: needed or detrimental [detrimental in attached Butler].
To make it clear, Mathcad Given Find is Mathsoft proprietary.
It has no competition in difficult applications.
Some projects toke weeks, from brain storm collaboration.
Cheers ... Enjoy Butler.
Solve Given_Find [CO2_6179].sm (34,34 КиБ) скачан 1486 раз(а).
#17 Опубликовано: 24.10.2019 12:48:45
Hello Jean,
It seems something is wrong here. Results seems to be doubtful and I think epsilon is missing as a third argument in FindRoot()
If I add it
Playing with the fourth argument will give
Moreover, roots() will fail
#18 Опубликовано: 24.10.2019 17:54:18
Hello Jean,
Quite right Radovan, many things don't cut the mustard !
1. "roots" fails in your version, but superb in my native SS 6179.
2. "epsilon" deteriorates the solver in this FindRoot application.
3. The system reacts like proportional/commutative wrt reactants.
What matters is the balance [Alkalinity] 0.0000012
sounds pretty good to me ? Should revisit the paper problem,
Reference: Butler, Carbon Dioxide Equilibria, Prob. 2-11, pg 41
#19 Опубликовано: 25.10.2019 09:58:44
I could not retrieve the very original.
Here is something.
https://www.isws.illinois.edu/pubdoc/CR/ISWSCR-171.pdf
