Vibrations of membranes
Vibrations of membranes - Messages
#1 Posted: 2017/12/28 17:10:57
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Vibrations of a circular membrane.The axisymmetric case
Solution are described with the help of Bessel functions .
https://en.wikipedia.org/wiki/Vibrations_of_a_circular_membrane
Bessel'2.sm (29.66 KiB) downloaded 1359 time(s).
Andrey Ivashov 2018/1/24 16:38:00, Davide Carpi 2017/12/29 12:53:00
#2 Posted: 2017/12/31 13:46:43
Tanks Ber7: saved in your named file.
#3 Posted: 2018/1/6 05:14:01
Fridel Selitsky
Fridel Selitsky
Vibrations of a rectangular membrane
Calculation formulas are taken from the book:S.Timoshenko,
Vibration Problems In Engineering
MemPl.sm (14.03 KiB) downloaded 1311 time(s).
Davide Carpi 2018/1/6 06:21:00, Andrey Ivashov 2018/1/24 16:37:00, frapuano 2018/1/6 08:26:00
#4 Posted: 2018/1/9 18:03:52
Fridel Selitsky
Fridel Selitsky
Vibrations of a circular membrane.The general case
Bessel'5.sm (22.49 KiB) downloaded 1322 time(s).
Andrey Ivashov 2018/1/24 16:37:00, Davide Carpi 2018/1/19 20:26:00
#5 Posted: 2018/1/19 12:37:31
Fridel Selitsky
Fridel Selitsky
Deflection of simply supported equilateral triangular plate
The plate rests on a frame in the form of an equilateral triangle.
The triangular part of the plate is loaded uniformly distributed
load. The equation of the surface of deflections of a triangular plate is taken
from the book of S.P.Timoshenko.Timoshenko S.P., Woinowsky-Krieger S. Theory of plates and shells. New York, NY: McGraw-Hill; 1959.
triangular plate.sm (12.86 KiB) downloaded 1282 time(s).
Andrey Ivashov 2018/1/24 16:37:00, Davide Carpi 2018/1/19 20:26:00, NDTM Amarasekera 2018/1/19 22:43:00
#6 Posted: 2018/1/19 14:47:19
Thanks Ber7 for that one and the other one few days ago.
#7 Posted: 2018/1/24 16:02:51
Fridel Selitsky
Fridel Selitsky
I tried to use the plugin Maxima
PlateMaxima.sm (143.87 KiB) downloaded 1332 time(s).
Andrey Ivashov 2018/1/24 16:37:00, frapuano 2018/1/24 19:43:00
#8 Posted: 2018/1/25 23:52:49
Thanks Ber7, I love those 3D, though it will never beat Mathcad 8... 11.
On my own, I published several times more than the entire Mathcad Community.
I don't miss them in Smath 6179, why ? purely useless for the Engineer.
They are just for the Gallery [Tom G. would say Peanut Gallery].
We are just waiting for a stable Smath version delivered with Maxima plugin
and more of the possible plugins. Scilab looks far superior to Maxima ?
#9 Posted: 2018/1/29 06:24:36
Fridel Selitsky
Fridel Selitsky
Deflection of a Circular Plate.Plate contains rigid
inclusion of radius b and loaded at the Center
(Timoshenko,S.and Woinowsky-Krieger, S.,Theory of plates and shells, 1959)
Inclusion.sm (32.68 KiB) downloaded 1297 time(s).
Davide Carpi 2018/1/29 07:29:00
#10 Posted: 2019/1/26 22:30:30
Laurent Fournier
Laurent Fournier
9 likes in 66 posts.
Hello Beer7, is this vibration of a rectangular membrane equivalent to the deflection of a simply supported, uniformly loaded, rectangular plate? (leaving aside the physical parameters like plate thickness, Young's modulus etc.) I am only interested in the curvature on various locations on the surface, not in absolute values (max deflection can be calculated using simple civil engineering formulaes).
Thanks,
Laurent
#11 Posted: 2019/1/27 00:30:46
Vibrations of a circular membrane.The axis symmetric case
Solutions are described with the help of Bessel functions .
Thanks Ber7, works great. Beautiful work.
mwbesselj(0,x) is ~ 4 times faster 15 decimals
Hart JZERO 5852 is 23 decimals up to ± 8.
Bessel JY.sm (75.19 KiB) downloaded 1247 time(s).
#12 Posted: 2019/1/27 01:55:42
What happened, your previous post is gone with the wind ???
Try this, so much faster !
Bessel mwbesselj Membrane Ber7 [20190126].sm (31.26 KiB) downloaded 1161 time(s).
#13 Posted: 2021/1/3 05:47:58
Fridel Selitsky
Fridel Selitsky
Vibrations of a triangular membrane
Calculation formulas are taken from thearticle:
http://ivdon.ru/uploads/article/pdf/IVD_44__1_Chernyshov.pdf_30f490557a.pdf
Vibration triangular membrane.sm (319.69 KiB) downloaded 1239 time(s).
Alvaro 2021/1/4 12:30:00
#14 Posted: 2021/1/3 11:28:34
Thanks, works fine after doctoring CreateMesh.
#15 Posted: 2021/1/3 13:23:53
Fridel Selitsky
Fridel Selitsky
Vibrations of a triangular membrane(Maxima)
TriangularMembrane Maxima.sm (279.28 KiB) downloaded 1350 time(s).
