1 Pages (10 items)
Solving tricky functions - Hertzian contact stress - Messages
Good day everyone,
I am building a Hertzian stress calculator and got stuck at the step where I calculate the k value for a particular B/A reationship.
Any help will be appriciated
contact stress calc.sm (22.69 KiB) downloaded 1115 time(s).
We also know than K will always be in the range (0,1)
The equations presented above is obtained from the book Advanced Mechanics of Materials by Boresi Et al
In case of these functions, al_nleqsolve() can be the answer.
No other solver is capable other than al_nleqsolve().
k' should be under line, otherwise not solveable.
Here is your function solved.
contact stress calc_1.sm (28.28 KiB) downloaded 1162 time(s).
I'm super impressed !!!
WroteYour original document is circular and indigestible.
From un-sourced [K,E] and arbitrary datum ... solve.
This sample is not appropriate.
As you have said, it is only solvable when K and E already given.
roots() can't solve without K and E given or calculated separately.
And you can't calculate K and E while not knowing what k is.
Your sample is not what OP wants.
He means to solve that complicated Q function.
Without any parameter or variable of K and E are pre-given.
WroteGood day everyone,
Solving by the old bisection method:
contact stress calc_by_bisection.sm (26.36 KiB) downloaded 1115 time(s).
Solving with a custom algorithm.
contact stress calc_2.sm (21.66 KiB) downloaded 1149 time(s).
WroteSolving with a custom algorithm.
Very elegant!
... slightly refreshed/augmented
Absent of comments from Originator !
Solve Circular Elliptic Datum Native Copy.sm (68.97 KiB) downloaded 1189 time(s).
1 Pages (10 items)
