Double pendulum model and animation
Double pendulum model and animation - Is the model correct? - Messages
#1 Posted: 2025/10/29 09:15:19
Valery Ochkov
Valery Ochkov
66 likes in 690 posts.
Hi friends!
Now I am on the forum again!
Anime2.sm (55.59 KiB) downloaded 797 time(s).
But the model is not correct. See please Alvaro model!
Edited 2025/10/30 19:22:14
#2 Posted: 2025/10/29 10:45:45
1,554 likes in 1,864 posts.
Using X-Y Plot
Anime2-xyplot.sm (57.84 KiB) downloaded 823 time(s).
sergio 2025/10/29 14:50:17, Ricardo_Herrera 2026/1/3 14:15:17
#3 Posted: 2025/10/29 11:14:52
Valery Ochkov
Valery Ochkov
Thanks, Слава!
Edited 2025/10/29 13:53:54
Alvaro 2025/10/30 07:04:33
#4 Posted: 2025/10/29 13:56:31
Valery Ochkov
Valery Ochkov
Anime-x-y-plot.sm (18.24 KiB) downloaded 790 time(s).
And where here is a bug?
#5 Posted: 2025/10/29 14:01:44
Vector t must be defined below before the component.
The animation feature is still being developed when I have time for it.
Edited 2025/10/29 14:05:45
Alvaro 2025/10/30 07:04:42
#6 Posted: 2025/10/29 17:02:10
Valery Ochkov
Valery Ochkov
Слава, а когда этот новая версия плагина появилась?
#7 Posted: 2025/10/29 18:19:29
Quote
В конце лета.
Edited 2025/10/29 18:21:02
#8 Posted: 2025/10/30 07:07:54
1,123 likes in 1,795 posts.
Hi. My approach to solving the double pendulum problem.
double_pendulum.sm (75.92 KiB) downloaded 845 time(s).
Вячеслав Мезенцев 2025/10/30 09:13:40, sergio 2025/10/30 12:18:26, Valery Ochkov 2025/10/30 07:45:32
#9 Posted: 2025/10/30 13:32:00
Valery Ochkov
Valery Ochkov
Newton vs Lagrange
Pendulum-2.xmcd (119.12 KiB) downloaded 809 time(s).
#10 Posted: 2025/10/30 18:31:11
Valery Ochkov
Valery Ochkov
My little edit
Alvaro 2025/10/31 04:29:45
#11 Posted: 2025/10/30 19:33:11
Valery Ochkov
Valery Ochkov
Triple pendulum - see errors at the second haft of time interval.
Pendulum-3-for-SMath.xmcd (220.62 KiB) downloaded 880 time(s).
Edited 2025/10/30 19:39:16
Alvaro 2025/10/31 05:05:16
#12 Posted: 2025/10/31 05:03:31
Hi. Using pure SMath code to deduce the equations of motion from the Lagrangian, with the functions in this post: https://smath.com/en-US/forum/topic/AeeMSM/Using-differentials.
double_pendulum_lagrangian.sm (174.64 KiB) downloaded 795 time(s).
double_pendulum_lagrangian.pdf (503.4 KiB) downloaded 614 time(s).
Valery Ochkov 2025/10/31 07:37:56, sergio 2025/10/31 08:48:37
#13 Posted: 2025/10/31 05:10:58
I no longer use Mathcad, except on rare occasions, when I rely on Mathcad version 11, which I consider the last decent version. So I can't see the triple pendulum file. And I suppose this is the situation for many SMath users who no longer have Mathcad readily available. But more than worrying about the conservation of energy, which seems to be a problem with the numerical method used, I'm more surprised to see how the future affects the past, since the animation shouldn't alter the trajectories already described by the particles as time passes.
This is my approach to the triple pendulum.
triple_pendulum_lagrangian.sm (135.01 KiB) downloaded 788 time(s).
triple_pendulum_lagrangian.pdf (248.09 KiB) downloaded 486 time(s).
Edited 2025/10/31 06:13:23
Valery Ochkov 2025/10/31 07:38:10, Вячеслав Мезенцев 2025/10/31 07:18:43
#14 Posted: 2025/10/31 07:35:30
Valery Ochkov
Valery Ochkov
See pls pdf
Pendulum-3-for-SMath.pdf (589.25 KiB) downloaded 524 time(s).
Edited 2025/10/31 07:38:52
#15 Posted: 2025/10/31 08:37:45
See pls pdf
With those values:
triple_pendulum_lagrangian.sm (159.26 KiB) downloaded 782 time(s).
Valery Ochkov 2025/10/31 10:39:04
#16 Posted: 2025/10/31 10:38:47
Valery Ochkov
Valery Ochkov
For me too!
#17 Posted: 2025/11/1 01:52:48
Valery Ochkov
Valery Ochkov
See pls pdf
With those values:
One my plot:
Change of three types of energy of a swinging pendulum on an elastic suspension - SE - the spring energy
Edited 2025/11/1 01:55:02
#18 Posted: 2025/11/5 07:01:02
Valery Ochkov
Valery Ochkov
Alvaro, hi!
Is it posibble to solve the single pendulun problem with Lagrangian and rkfixed but without the al_nleqsolve function?
Edited 2025/11/5 08:29:15
#19 Posted: 2025/11/6 04:03:01
Hi Valery. For the single pendulum you can get the lagrangian from the olf post about differentials ( https://smath.com/en-US/forum/topic/AeeMSM/Using-differentials ) It's very simple and doesn't require much processing to use rkfixed.
For the double pendulum, you can use Newton-Raphson to solve the system within the function D. Here, a very simple version of the method is used.
double_pendulum_lagrangian-NR.sm (178.15 KiB) downloaded 794 time(s).
Something similar applies to the pendulum with a spring. Note that the Lagrange equations become somewhat complicated because I use the x,y coordinates to calculate the kinetic energy, and SMath cannot simplify trigonometric functions. However, if you use r, θ' (in green), the equations of motion are greatly simplified. But that breaks the principle that the program should do the calculations, not the user.
Valery Ochkov 2025/11/6 05:16:18
#20 Posted: 2025/11/6 11:47:20
Valery Ochkov
Valery Ochkov
Hi Alvaro!
Can you create this simple sm-file with animation? Single pendulum!
Thanks!
