Problem with integral
Problem with integral - Messages
#1 Posted: 2019/4/1 13:53:58
dzon_doe
dzon_doe
0 likes in 2 posts.
I have a problem with the integral. Please find the exemplary attached to this post. I have defined several variables and their units. In my opinion, everything is OK but SMath does not solve it when the temperature is defined as a vector T, or solve only the first integral if temperatures are defined separately (as T.1 and T.2). Can you explain to me why SMath cannot solve this integral?
int_issue.sm (8.04 KiB) downloaded 1014 time(s).
Best regards,
dzon_doe
#2 Posted: 2019/4/1 15:32:36
Sure it integrates an integrand and more.
int_issue.sm (11.65 KiB) downloaded 1053 time(s).
#3 Posted: 2019/4/1 16:02:09
dzon_doe
dzon_doe
0 likes in 2 posts.
To be honest, your explanation is not clear for me but I noticed that you removed all units. And in my sheet, it also works. Does the units the source of the problem?
Best regards,
dzon_doe
#4 Posted: 2019/4/1 17:22:29
You first wrote:
Can you explain to me why SMath cannot solve this integral ?
Now you reply: And in my sheet it also works.
Maths are unitless, so I reject carrying units,
there are very many instances not supporting units.
Units were discussed ad nauseum in Mathsoft forum,
in > 125000 exchanges: not a single work sheet in units.
#5 Posted: 2019/4/1 18:31:52
1,123 likes in 1,795 posts.
Hi. Try this:
#6 Posted: 2019/4/1 20:22:41
1,355 likes in 2,271 posts.
Maxima can handle integrals with units. Yet the restriction applies that the integration variable must be undefined.
int_issue_Kr_units.sm (10.14 KiB) downloaded 1021 time(s).
#7 Posted: 2019/4/1 22:49:00
Native Smath does it in much greater elegance.
int_issue [Transit Method].sm (9.39 KiB) downloaded 808 time(s).
#8 Posted: 2019/4/2 09:14:40
Refreshed version managed from annoying units
Integral 0000000 Transit-Units.sm (23.78 KiB) downloaded 1029 time(s).
