1 страниц (8 вхождений)
Problem with integral - Сообщения
I have a problem with the integral. Please find the exemplary attached to this post. I have defined several variables and their units. In my opinion, everything is OK but SMath does not solve it when the temperature is defined as a vector T, or solve only the first integral if temperatures are defined separately (as T.1 and T.2). Can you explain to me why SMath cannot solve this integral?
int_issue.sm (8,04 КиБ) скачан 1150 раз(а).
Best regards,
dzon_doe
Best regards,
dzon_doe
WroteCan you explain to me why SMath cannot solve this integral?
Sure it integrates an integrand and more.
int_issue.sm (11,65 КиБ) скачан 1193 раз(а).
To be honest, your explanation is not clear for me but I noticed that you removed all units. And in my sheet, it also works. Does the units the source of the problem?
Best regards,
dzon_doe
WroteTo be honest, your explanation is not clear for me but I noticed that you removed all units. And in my sheet, it also works. Does the units the source of the problem?
You first wrote:
Can you explain to me why SMath cannot solve this integral ?
Now you reply: And in my sheet it also works.
Maths are unitless, so I reject carrying units,
there are very many instances not supporting units.
Units were discussed ad nauseum in Mathsoft forum,
in > 125000 exchanges: not a single work sheet in units.
Maxima can handle integrals with units. Yet the restriction applies that the integration variable must be undefined.
int_issue_Kr_units.sm (10,14 КиБ) скачан 1163 раз(а).
WroteMaxima can handle integrals with units. Yet the restriction applies that the integration variable must be undefined
Native Smath does it in much greater elegance.
int_issue [Transit Method].sm (9,39 КиБ) скачан 946 раз(а).
Refreshed version managed from annoying units
Integral 0000000 Transit-Units.sm (23,78 КиБ) скачан 1178 раз(а).
