error: result is above max
error: result is above max - Messages
#1 Posted: 2021/5/28 10:21:06
takeo kusumi
takeo kusumi
0 likes in 3 posts.
hi,
I'm a beginner
I get an error in the calculation
error :
result is above max. Allowed positive number
How can I solve it?
impedance.sm (34.02 KiB) downloaded 633 time(s).
#2 Posted: 2021/5/28 10:39:29
580 likes in 1,349 posts.
hi,
I'm a beginner
error :
How can I solve it?
Change your calculation result from symbolic to numeric.
You can do it with eval() since they are all numbers.
#3 Posted: 2021/5/28 15:27:57
takeo kusumi
takeo kusumi
0 likes in 3 posts.
Thank you
I understand the cause of the error
#4 Posted: 2021/5/28 18:40:26
eval() is a general rule but an absolute rule.
Many projects fail from eval(,).
SS 6179 does not complain as you constructed.
eval(,) is applied afterwards to isolate/accelerate.
#5 Posted: 2021/5/28 20:33:21
Good application case to globalize within the program.
... in my SS 6179 timing drops from 2.6 s down to 1.6 s
#6 Posted: 2021/5/28 20:55:57
takeo kusumi
takeo kusumi
0 likes in 3 posts.
Thank you.
I was able to calculate the frequency characteristics
(PP2.sm)
But when I modify a circuit, I get an error even with eval.
(PPS.sm)
it's very difficult.
PPS.sm (176.46 KiB) downloaded 631 time(s).
PP2.sm (167.69 KiB) downloaded 625 time(s).
#7 Posted: 2021/5/29 10:50:48
Thank you.
(PP2.sm)
(PPS.sm)
... sorry, can't help: this document opens freak SS 6179.
You seem to put too much that can't be debugged piece wise.
#8 Posted: 2021/5/29 12:11:55
1,078 likes in 1,749 posts.
Thank you.
(PP2.sm)
(PPS.sm)
Hi Takez. Yes, it's very difficult recognize or even guess where the program needs some evals. Also, putting them everywhere make unreadable the procedures. In the case of your PPS.sm that's SMath stores into Z without eval
and this with it
So, for PPS.sm there is where you need to use eval, and seems that then all other calculations works.
#9 Posted: 2021/5/29 12:33:20
Razonar's is the correct solution.
Deleting my post.
Alvaro 2021/5/29 17:56:00
