Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Messages
#81 Posted: 2023/1/17 09:19:38
German
German
0 likes in 8 posts.
Here it is.
losa-forum.sm (862.11 KiB) downloaded 1697 time(s).
Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
#82 Posted: 2023/1/17 10:18:15
Sorry Jean but I don't understand what I'm supposed to see. I also get "data - not defined".
data not defined probably indicates some plugins not installed.
Maybe other problems wrt your version.
#83 Posted: 2023/1/17 10:55:42
Here it is.
Document does not open ... incorrect format
#84 Posted: 2023/1/17 11:15:28
German
German
0 likes in 8 posts.
SMath Studio Desktop 64-bit
Version: 1.0(build: 8348)
Date: 9/11/2022
ConditionallyFormattedLabel: 1.0.8138.35454
#85 Posted: 2023/1/17 11:20:05
1,443 likes in 2,935 posts.
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error.
The same happens if you try to force a numerical evaluation using eval()
#86 Posted: 2023/1/17 12:05:21
German
German
0 likes in 8 posts.
That is it!
As allways thanks!!
But still don't understand why Jean files fails.
#87 Posted: 2023/1/17 12:12:05
Date: 9/11/2022
Slide left the Formatted Label
Side right the graph, remove the Σ no definido
You should see the plot.
#88 Posted: 2023/1/17 12:15:52
That is it!
As allways thanks!!
You're welcome!
There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter. nevermind I was looking at your file.
If you remove the 3 inline evaluations it will work.
2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png
#89 Posted: 2023/1/17 12:39:57
German
German
0 likes in 8 posts.
My file can be an example of things NOT to do.
#90 Posted: 2023/10/14 23:08:58
Rogalski
Rogalski
0 likes in 7 posts.
Can we manage the units that are displayed?
I have a load in kN/m2 and the result appears as kg/(m*s2).
The idea is to present only positive values (with the appropriate unit).
kind regards
Conditionally Formatted Labels_unity.sm (5.47 KiB) downloaded 1660 time(s).
#91 Posted: 2023/10/14 23:52:58
The easier way might be something like this
2023-10-14 18_53_23-SMath Solver - [Conditionally Formatted Labels_unity.sm_].png
press2text(x):line(concat(var2str(x/'kPa,1),"\0020\kN\002F\m\00B2\",1,1)
Oscar Campo 2023/10/15 00:41:00
#92 Posted: 2023/10/15 00:08:06
Rogalski
Rogalski
0 likes in 7 posts.
Thank you very much.
This is exactly what I needed.
#93 Posted: 2023/10/15 23:51:23
Rogalski
Rogalski
0 likes in 7 posts.
I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
#94 Posted: 2023/10/16 03:06:16
You can subscribe whatever.
mysystem dot HelloGrandMa
#95 Posted: 2023/10/17 01:32:30
Rogalski
Rogalski
0 likes in 7 posts.
thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing.
Davide sent the function shown above in which I need to use subscripts.
#96 Posted: 2023/10/17 02:13:46
Oscar Campo
Oscar Campo
135 likes in 309 posts.
Davide used superscript unicode character for write: "kN\002F\m\00B2\" wich renders as "kN/m²" so, you can use unicode characters...but not all characters have subscript version.
Please check here: https://www.compart.com/en/unicode/search?q=subscript#characters
Oscar
#97 Posted: 2023/10/17 13:30:37
1,123 likes in 1,795 posts.
Hi Karol. This could be a workaround, using the SMath Plot region.
label.sm (6.22 KiB) downloaded 1650 time(s).
Oscar Campo 2023/10/17 16:52:00
#98 Posted: 2023/10/17 18:15:56
Subscripts in native Solver 30405.
Collect as many the project needs,
call the wanted by indexing.
Maths Subscript.sm (10.73 KiB) downloaded 1660 time(s).
#99 Posted: 2023/10/17 23:23:29
Rogalski
Rogalski
0 likes in 7 posts.
Wow great Alvaro. Thank you very much.
I'm impressed.
#100 Posted: 2023/10/17 23:26:39
Rogalski
Rogalski
0 likes in 7 posts.
Jean Giraud,
Thank you too.
But I have to put in some effort to understand what you sent.
Kind regards
