Newbie problem - Using a range of angles inside a cosine function
Newbie problem - Using a range of angles inside a cosine function - Trying to use cos(variable angle) - Сообщения
#1 Опубликовано: 03.10.2012 06:41:00
jjuddgb
jjuddgb
I'm trying to convert some old Mathcad files into SMath but am stuck with what must be an elementary problem, I've looked at various tutorials but can't find a solution, no doubt due to my own incompetence.
I am defining the following variables: angle:=72 and varangle:= 0, angle/2..360
In Mathcad if I then define: test(varangle):= cos(varangle) the output of test(varangle) displays correctly in a column.
If I try the same in SMath I receive either an 'argument must be scalar' or 'fill in all empty elements' error.
Thanks for any advice.
Screenshots of Mathcad and SMath attached.
btw, great software.
Mathcad - output.pdf (26,44 КиБ) скачан 949 раз(а).
#2 Опубликовано: 03.10.2012 07:49:27
kilele
kilele
Correct me if i'm wrong, trigonometric functions don't support arrays currently.
For now, you can do something like this.
cosinOfArray.sm (5,04 КиБ) скачан 1812 раз(а).
1752 28.09.2024 14:44:00
#3 Опубликовано: 03.10.2012 11:09:17
jjuddgb
jjuddgb
Thank you kilele
#4 Опубликовано: 03.10.2012 11:31:19
Fridel Selitsky
Fridel Selitsky
You can convert the vector into a system (by w3b5urf3r_reloaded)
Regards, Ber7
https://smath.com/wiki/GetFile.aspx?File=cosinOfArray%5b1%5d.rar
Davide Carpi 03.10.2012 13:33:00
#5 Опубликовано: 03.10.2012 11:33:28
Fridel Selitsky
Fridel Selitsky
Regards, Ber7
#6 Опубликовано: 28.09.2024 14:44:50
1752
1752
did arrays appear in trigonometric functions?
#7 Опубликовано: 28.09.2024 16:09:41
now you can use the "vectorize" function, which you also find in the side panel, and perform the trigonometric function element by element.
1752 28.09.2024 16:30:00
#8 Опубликовано: 29.09.2024 22:22:50
An alternative to the vectorize() function is the use of index vectors.
They, however, only work if they are used in a definition.
Worksheet1.sm (5,28 КиБ) скачан 1580 раз(а).
sergio 29.09.2024 23:37:00
