DISLIN
DISLIN - A high-level plotting library for displaying data - Сообщения
#41 Опубликовано: 04.04.2016 15:30:31
Jean, on a side note, what is your comment on a quality of DISLIN generated plots?
There are already so many 3D plots, many are freeware.
Scilab, DISLIN ... Surfer 8 [dedicated Contour plot, not freeware].
I see DISLIN via a menu driven and equation editor, Mathcad style.
The first thing is a the same CreateMesh than Mathcad. Let say the
two planes X, Y and the level Z plane and in parametric style.
That sets the complete 3 D system, meshed at will and supporting
the entire user rotation from command line as well as cylindrical/
spherical plots and export the corresponding matrices. Contour is
something else of much different nature. Contour plots ends being
an XY plot. I have a Mathcad contour program [done by Collab].
Just scared to attempt Coding in Smath. Some of you gurus, I can
make an image of the program for your bed time reading.
There remains the question about freeware: how far can somebody
reverse Engineer and redistribute ?
Cheers Alex, Jean
#42 Опубликовано: 04.04.2016 18:54:22
... that's what I meant about a comprehensive "DISLIN start".
Contour is for exporting specific contour data. The feed is a
matrix, either well populated or splined and you get what you
want. Collapse the function, plug the matrix from source or
from function ... ready for the contour(s), just few clicks.
I lost patience trying to imitate Mathcad "on error".
So, attempting the program is not tempting.
The program images included in the *.sm work sheet.
Contour Electron.sm (239,09 КиБ) скачан 2120 раз(а).
Alexander O. Melnik 04.04.2016 19:01:00
#43 Опубликовано: 27.10.2020 08:50:31
2 343 сообщений из 4 047 понравились пользователям.
Группа: Super Administrator
Hello.
Currently I'm working to improve SMath Studio start up time. Have good results (made it up to 4x faster), but I've found that DISLIN plug-in requires from 4 to 14 seconds (different environment) to response on call to GetTermsHandled. Which is the most significant part of SMath Studio start up time.
Is it possible to improve the logic here?
#44 Опубликовано: 27.10.2020 09:02:58
1 555 сообщений из 1 867 понравились пользователям.
I'll see what I can do or will change the way I use it.
Andrey Ivashov 27.10.2020 09:22:00, Davide Carpi 27.10.2020 11:02:00, sergio 27.10.2020 11:51:00
#45 Опубликовано: 04.11.2020 16:23:17
Updated. Refactored. Startup time has been reduced.
Andrey Ivashov 05.11.2020 06:34:00
#46 Опубликовано: 04.11.2020 23:36:55
... native SS 6179 ... sorry but I have no interest *.svg
Stand alone user command line is more my cup of tea.
#47 Опубликовано: 05.11.2020 12:34:36
EULA
Updated.
Changes:
- updated to DISLIN 11.3.3 (799 functions);
- refactored.
Цитата
Grant of Free Usage
You are allowed to use DISLIN for free. Either as a private person or in a
commercial or non-commercial environment. There are no limitations.
Click to enlarge
DISLIN. Example 1.sm (95,34 КиБ) скачан 2154 раз(а).
DISLIN. Example 1.pdf (287,2 КиБ) скачан 1461 раз(а).
Andrey Ivashov 05.11.2020 19:12:00, NDTM Amarasekera 05.11.2020 22:32:00
#48 Опубликовано: 01.06.2022 14:30:37
SMath Studio compatibility
Plugin updated.
Changes:
- updated to DISLIN 11.5 (799 functions);
- string encoding bug fixed;
- refactored.
sergio 01.06.2022 16:46:00, João Felipe Seráfico Melo 01.06.2022 21:58:00, NDTM Amarasekera 01.06.2022 22:30:00, Mark R Harris 02.06.2022 03:36:00
#49 Опубликовано: 29.01.2025 01:32:17
Plugin updated:
- Text descriptions added to the functions implemented in the plugin (>90% descriptions found).
Вячеслав Мезенцев 29.01.2025 02:03:00, Oscar Campo 29.01.2025 02:33:00, NDTM Amarasekera 30.01.2025 10:41:00
#50 Опубликовано: 29.01.2025 22:19:59
Here you need to keep in mind that the source file with a list of functions is automatically formed using the template distinct.tt. Therefore, it is advisable to come up with a way of automatically adding a description to each function.
