Beta: SMath Studio 0.99.7542 (25 August 2020)
Beta: SMath Studio 0.99.7542 (25 August 2020) - Сообщения
#1 Опубликовано: 24.08.2020 20:24:09
Группа: Super Administrator
Изменения, входящие в версию 0.99.7542
Улучшения
  • COUNT and PAGENUM fields improved to allow setting up an offset for the output number;
  • Alignment context menu item added to TextRegion;
  • TextRegion improved to support changing Line spacing using context menu.
Исправления
  • trunc() function does not accept units in the argument anymore;
  • Empty Heder/Footer supported now;
  • Basic behaviors of the TextRegion improved (text selections);
  • SS-4612 Line wrapping significantly improved in TextRegion;
  • Fixed "There is no xml start tag" issue happens when self-closed tag of the Region was included into *.sm(z) file;
  • Functionality of the " " (space) key fixed in case when no plug-in for Text Region is available;
  • equrep() function supports variables/functions replacements now.
Разное
  • Support for .Net Core 3.1 implemented (app is still released supporting .Net 2.0 for now);
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_7542.Mono.tar.gz (1,4 МиБ) скачан 2864 раз(а).
SMathStudioDesktop.0_99_7542.Setup.msi (2,27 МиБ) скачан 6282 раз(а).
10 пользователям понравился этот пост
Вячеслав Мезенцев 25.08.2020 01:18:00, sergio 25.08.2020 04:55:00, Denis Nikitin 25.08.2020 06:41:00, IVR 25.08.2020 09:16:00, NDTM Amarasekera 25.08.2020 11:51:00, Arie 25.08.2020 12:38:00, frapuano 26.08.2020 03:32:00, Serg 26.08.2020 11:34:00, Davide Carpi 28.08.2020 14:36:00, Василий Николаевич Храмушин 20.09.2020 09:58:00
#2 Опубликовано: 25.08.2020 06:26:19
Hi. Thanks! Very much!
"equrep() function supports variables/functions replacements now."
Any example about what that means?
Also, I see that this error persists:
#3 Опубликовано: 25.08.2020 18:07:08
Hello Alvaro!
Yes, this is a main reason why I can't release stable version of SMath Studio now. I'm working on this issue right now.
Alvaro 25.08.2020 20:27:00
#4 Опубликовано: 27.08.2020 17:11:26
Any example about what that means ?
Can you show an application of it ?
An image is good enough.
Thanks ... Jean
#5 Опубликовано: 27.08.2020 21:24:31
Thanks ... Jean
Hi Jean. Here: Applications for equrep: expression isolation and laplace transform.
IVR 29.08.2020 12:29:00, frapuano 28.08.2020 02:53:00
#6 Опубликовано: 29.08.2020 06:54:30
Thanks ... Jean
Just to make it clear: equrep() function is not something I'm spending time on to create/support/improve. This function appeared as a demo of the updated symbolic core of SMath Studio. This function is an interface to the new functionality. You can use it or not, but it demonstrates possibilities of the symbolic simplifications SMath Studio provides.
Unfortunately it has at least one issue which is hard to fix. I'm doing my best to remove a bug, but if it will be too hard maybe I will revert my changes and use stable (which is used in latest stable version of the application) symbolic core again.
So it is not about equrep() function it is about core of the program, its performance, possibilities, behaviors etc. If you are remember, all the calculations in SMath Studio goes through symbolic optimization, so it is pretty important.
sergio 29.08.2020 12:58:00, Serg 30.08.2020 09:20:00, IVR 29.08.2020 12:29:00, frapuano 29.08.2020 12:34:00
#7 Опубликовано: 30.08.2020 12:12:30
Thanks Alvaro ... always there in Smath Community !
BTW Andrey, if/else, if/otherwise have not been observed
detrimental in timing in general applications.
For this application [Julia], timing kills Smath ... Oh !
OK, my Win 7 1.66 GHz is steam engine.
What about your latest Beta SS 7542 ?
Thanks ... Jean
Pattern Julia Set [PUBLISH].sm (172,79 КиБ) скачан 1654 раз(а).
#8 Опубликовано: 30.08.2020 16:33:41
Maybe it is a bug maybe intended I don't know;
On 7542 for underlined text regions, spaces are not underlined.
No problem for letters, numbers, punctuations, etc.
Writer regions don't have this issue.
#9 Опубликовано: 09.09.2020 12:12:34
I can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542.
In 7251 this still works. It also works for documents produced in 7542.
#10 Опубликовано: 09.09.2020 19:32:12
Thank you! Fixed.
#11 Опубликовано: 09.09.2020 19:33:22
I can't reproduce this issue locally. Please could you upload a files (one with correct behavior and another with incorrect)?
#12 Опубликовано: 10.09.2020 07:16:24
I attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed.
If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry.
Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour.
7542 displays existing files correctly. Just no access to this one setting.
I leave out the maxima draw region, as this might prevent reproduction without maxima installation.
border 7542.sm (7,87 КиБ) скачан 1947 раз(а).
border 7542 then 7251.sm (7,87 КиБ) скачан 1918 раз(а).
Andrey Ivashov 13.09.2020 07:33:00
#13 Опубликовано: 13.09.2020 07:35:16
Thank you very much. Fixed now.
There is one issue with the plug-in: invalidation of the region is not requested after menu item usage (it must be done by plug-in) so borders will be visually switched only after region redrawn, f.e. after scrolling or focus in/out.
Martin Kraska 13.09.2020 18:42:00
#14 Опубликовано: 13.09.2020 16:55:14
Issue is fixed in the latest stable version I have just published. equrep() made less powerful, so it will leave an equation as is in cases where error is possible. Like your example.
This is temporary solution but it is required to continue development without serious stoppers. In future I will continue working to make symbolic engine more smart.
Alvaro 13.09.2020 17:11:00
#15 Опубликовано: 13.09.2020 19:00:12
This also seems to be the cause for delayed re-draw after editing operation (you have to get focus off the image to see the changes). Very valuable hint!
Filed in the bug tracking system as SS-4640
#16 Опубликовано: 16.09.2020 18:43:50
I post that question because interpret that then equrep works replacing f by sin in this example: "equrep(3+f(x),f,sin)=3+f(x)" but now I see that the correct way is "equrep(3+f(x),f(a),sin(a))=3+sin(x)"
Here my attempt to convert an expression with operators to an expression with binary or unary functions only
_to_expr.sm (51,03 КиБ) скачан 1961 раз(а).
_to_expr.pdf (223,76 КиБ) скачан 1152 раз(а).
#17 Опубликовано: 30.10.2021 20:11:38
Rematch ... It's seems to work now.
num2expr.sm (39,06 КиБ) скачан 1845 раз(а).
num2expr.pdf (176,65 КиБ) скачан 1304 раз(а).
sergio 31.10.2021 12:37:00
