Vectors creation with ranged indices
Vectors creation with ranged indices - How to use vectors with subscripts (by typing: [) - Messaggi
#1 Pubblicato: 21/03/2018 10:17:31
Rens
Rens
0 apprezzamenti in 4 post.
Does anyone know how to use vectors with subscripts (by typing: [) in SMAth as I have done in the attached Mathcad file (.pdf + .xmcd). I have tried it in SMath (see the attached SMath file) but this does not work in the same way. Does anyone knows a workaround?
Best regards,
Rens Servais
File non trovato.File non trovato.File non trovato.
#2 Pubblicato: 21/03/2018 10:54:39
Gruppo: Moderator
Hello Rens,
You can do it in the same way, but indices here are base 1 instead of base 0
SMath file (r1).sm (4,53 KiB) scaricato 1210 volta(e).
#3 Pubblicato: 22/03/2018 07:12:23
Rens
Rens
Thanks a lot Davide!
Rens
#4 Pubblicato: 22/03/2018 11:09:04
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2,93 KiB) scaricato 1291 volta(e).
#5 Pubblicato: 22/03/2018 11:20:17
Gruppo: Moderator
What would be the expected result?
#6 Pubblicato: 22/03/2018 11:26:42
Arie
Arie
94 apprezzamenti in 285 post.
You had Count as subscript instead of index in the loop.
Range2Vec program.smz (2,93 KiB) scaricato 1293 volta(e).
#7 Pubblicato: 22/03/2018 11:26:57
Ruben Sidranski
Ruben Sidranski
Wrong subscript ... Fixed Range2Vec.smz (3,31 KiB) scaricato 1320 volta(e).
