1 pagine (7 elementi)
Vectors creation with ranged indices - How to use vectors with subscripts (by typing: [) - Messaggi
Does anyone know how to use vectors with subscripts (by typing: [) in SMAth as I have done in the attached Mathcad file (.pdf + .xmcd). I have tried it in SMath (see the attached SMath file) but this does not work in the same way. Does anyone knows a workaround?
Best regards,
Rens Servais
File non trovato.File non trovato.File non trovato.
Best regards,
Rens Servais
Hello Rens,
You can do it in the same way, but indices here are base 1 instead of base 0
SMath file (r1).sm (4,53 KiB) scaricato 1210 volta(e).
![2018-03-21 14_55_53-SMath Studio - [SMath file (r1).sm_].png](/it-IT/files/Download/rZcxyq/2018-03-21-14_55_53-SMath-Studio---[SMath-file-(r1).sm_].png)
Thanks a lot Davide!
Rens
Rens
Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2,93 KiB) scaricato 1291 volta(e).
WroteReminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2,93 KiB) scaricato 1291 volta(e).
What would be the expected result?
You had Count as subscript instead of index in the loop.
Range2Vec program.smz (2,93 KiB) scaricato 1293 volta(e).
Wrong subscript ... Fixed Range2Vec.smz (3,31 KiB) scaricato 1320 volta(e).
