1 pagine (18 elementi)
Syntax for linterp - What is the correct syntax for linterp(x,y,z) - Messaggi
Sorry to be so slow on Smath. Some thing work like Mathcad and some don't. I need help with the correct syntax for the interpolation function linterp. I have tired all combinations of syntax that I can think of and none work in the attached Smath file.
Help would be appreciated.
RMD CALCULATION.sm (15,13 KiB) scaricato 1293 volta(e).
I don't think vectorize works with this function. It is expecting a single value in argument 3. Checkout my linterp2 function in the attached. I think it does what you want.
RMD CALCULATION.sm (18,24 KiB) scaricato 1265 volta(e).
Note: In my program, it is not necessary to initialize the result. However, I have found that in cases of large vectors, it speeds up processing time to initialize a vector to the expected size and then fill in values. I generally just do this as standard practice now even if it's not necessary.
Thanks much. You are a real help.
I did not realize that the interpolation functions required additional programming. I incorrectly assumed it was like Mathcad. Many things are like Mathcad, but clearly not all.
Thanks again.
Reg
Thanks again.
Reg
No problem!. Welcome to the forum. There are a lot of people here who are regular contributors and will help you with questions you have. For me, it's why I primarily use SMath for my calculations.
Regarding similarity/dissimilarity to MathCAD... once you start using SMath more you'll stop thinking in "MathCAD" and be able to think in "SMath". As a former MathCAD convert myself, I really started to come into my own when I stopped thinking of how I would do things in MathCAD and started figuring out how best to use SMath.
WroteSome thing work like Mathcad and some don't.I need help with the correct syntax for the interpolation function linterp.
Read carefully: linterp, cinterp are 1/1 Mathcad
Smath ainterp has special virtues not found in Mathcad.
Smath linterp, cinterp, ainterp are 1/1 Mathcad as interpolation.
but are 0/1 as scalar functions. In many instances, it is possible
to recast the problem in the form of infinitesimal analysis.
I found no way to render a_c_l interp scalar Mathcad style.
Though, I have the Mathcad code. Don't confuse yourself, a_c_l_interp
they plot on the canvas, i.e: they plot scalar.
scalar is a kernel internal vanishing iterator
Next question: please attach the Smath document.
WroteOops I meant this way to no success.
RMD CALCULATION (J).sm (18,81 KiB) scaricato 1275 volta(e).
Jean,
I appreciate your attempt at helping me. Unfortunately, I am new to Smath and don't really understand your syntax in your attached sm file. See my comments in the attached file.
WroteWroteOops I meant this way to no success.
RMD%20CALCULATION%20(J)-1.sm (21,15 KiB) scaricato 1409 volta(e).
Sorry, I am just too new to this code to appreciate your input.
Thanks again,
Reg
Hi. You can do some plots too.
RMD CALCULATION.sm (10,79 KiB) scaricato 1300 volta(e).
Thanks to all. I was able to find some useful stuff from everyone. Here is where I was headed.
RMD CALCULATION.sm (16,94 KiB) scaricato 1217 volta(e).
WroteSorry, I am just too new to this code to appreciate your input.
Thanks again,
Reg
Hello Reg ... answered in blue
RMD CALCULATION (J in_blue)-1.sm (24,61 KiB) scaricato 1232 volta(e).
Just a note.
Pay attention to the plot by Alvaro. He uses often neded lele() function (Custom functions plugin) for checking if the value is in a range: Xmin<=x<=Xmax
frapuano 15/02/2019 05:52:00
WroteThanks to all.I was able to find some useful stuff from everyone.
... more in there for publishing.
Little Smath doing so much, so nice !
RMD CALCULATION (J).sm (35,64 KiB) scaricato 1268 volta(e).
Is this XY plot new? I find it really helpful.
RMD CALCULATION.sm (18,33 KiB) scaricato 1222 volta(e).
WroteIs this XY plot new?I find it really helpful.
Not new, just from applied Smath features as in older SS 6179.
