Phasor
Phasor - Messaggi
#1 Pubblicato: 18/05/2019 20:02:12
Basile
Basile
8 apprezzamenti in 172 post.
I need to draw phasors (lines-vectors) for AC circuit analysis.
- Line from origin to a point.
- Line from a point to another
The magnitude and the angle or Real and Imaginary parts are known.
Is there any related example?
Thank you,
Basile
#2 Pubblicato: 19/05/2019 10:00:57
Brute force quick
#3 Pubblicato: 20/05/2019 01:05:14
Basile
Basile
Thank you Jean.
Any way to use different colour for some segments?
Put an arrow or a circle at the end?
Have a text to identify each segment?
Basile
#4 Pubblicato: 20/05/2019 02:25:58
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
You can use X-Y Plot Region for this.
XYPlot. Draw shapes.sm (19,85 KiB) scaricato 3279 volta(e).
XYPlot. Draw shapes.pdf (92,91 KiB) scaricato 2286 volta(e).
#5 Pubblicato: 20/05/2019 09:24:12
Thank you Jean.
Basile
Hello Basile,
You should be able to build your circuit with the attached.
Make something, attach and we will add text if you can't.
Circle_rkfixed Arrow.sm (27,63 KiB) scaricato 1258 volta(e).
2D Util Bar Arrow Model.sm (22,97 KiB) scaricato 1231 volta(e).
Circle_rkfixed Clock.sm (23,28 KiB) scaricato 1272 volta(e).
#6 Pubblicato: 22/05/2019 10:52:49
Thank you Jean.
Basile
Hello, Basile
On that one you can do a bit more.
Too much may be too much, isn't ?
Maths Polygon.sm (17,1 KiB) scaricato 1271 volta(e).
#7 Pubblicato: 23/05/2019 12:22:45
Basile
Basile
Hello Jean and Uni,
Why the Lv is not defined?
I express the matrices as function.
And then the vectors evaluate!
What are the red squares to the right?
It looks that this approach of drawing vectors is a begging.
I shall work on it.
Thank you,
BasilePage2-error.sm (12,71 KiB) scaricato 1372 volta(e).
#8 Pubblicato: 23/05/2019 20:32:28
Red square in the scroll bar points at the errors in the document.
More elegant arrows proposed.
Page2-error.sm (8,34 KiB) scaricato 1423 volta(e).
NDTM Amarasekera 26/05/2019 05:25:00
#9 Pubblicato: 24/05/2019 15:09:24
Basile
Basile
Hi Jean,
The arrows fail when the length of the vector changes.
I have tried as a percentage of length but does not look nice.
Scaling the vectors to always be one but will loose real valuesSMath-1.PNG.
Any good idea?
Is there a way to auto-scale the 2D plot or X-Y plot?
One of the vectors is out of the visual plane.
Thanks,
Basile
#10 Pubblicato: 24/05/2019 15:19:13
Gruppo: Moderator
As I said before:
How about a simple arrow?
I do not know how to do it better. The arrow should look good in different scales and in its own size.
#11 Pubblicato: 24/05/2019 17:35:33
Any good idea?
None of the quick plot or X_Y plot can be made X, Y directions scalable
similar to Mathcad 11 ... to me: useless.
From an original X_Y plot creation, stretch by handles respect aspect ratio.
If you modify the X, Y directions [max/min], apply close enough HL, HW ratio.
Page2-error (1).sm (11,66 KiB) scaricato 1438 volta(e).
NDTM Amarasekera 24/05/2019 23:22:00, frapuano 25/05/2019 02:46:00
#12 Pubblicato: 24/05/2019 22:44:11
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
Another kind of arrow.
Arrow.sm (5,46 KiB) scaricato 1182 volta(e).
NDTM Amarasekera 24/05/2019 23:22:00, frapuano 25/05/2019 02:46:00, Вячеслав Мезенцев 25/05/2019 06:08:00
#13 Pubblicato: 25/05/2019 21:24:37
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
With both arrow heads, based on Jean's method.
Thank you Jean.
Both Arrows.sm (30,49 KiB) scaricato 1214 volta(e).
#14 Pubblicato: 26/05/2019 00:52:40
Basile
Basile
Why I am getting errors when load your file?
The latest Stable: SMath Studio 0.99.7030 (01 April 2019)
At the end I am able to open the file.
I do the same with two arrows 2π apart, but yours is more elegant.
Basile
