Simple beam analysis, graph
Simple beam analysis, graph - Simple beam analysis, graph - Messaggi
#1 Pubblicato: 14/12/2025 03:22:09
kimkim
kimkim
0 apprezzamenti in 9 post.
Hi every one. I have some questions.
Q1) When performing symbolic calculations, I currently have to manually set the optimization to 'numeric' (or 'symbolic'/'none') for each region individually. Is there a way to change the default optimization setting to 'symbolic' or 'none' globally?
Q2) I have created a worksheet for the SFD and BMD of a simple beam, as shown in the image. I am trying to plot these diagrams using the XY Plot component.How can I restrict the x-axis range to display only the interval from 0 to 1?How can I mark the specific point of M_max on the graph?
Thank you for all.
12.SimpleBeam_01.sm (63,68 KiB) scaricato 946 volta(e).
#2 Pubblicato: 14/12/2025 09:48:29
StvMath
StvMath
44 apprezzamenti e 1 disapprezzamenti in 76 post.
a. From Edit menu select All, then right-click on any blue region and select None from the optimisation section.
b. Double click on the graph and select the various options on the resulting menu - see attached.
12.SimpleBeam_01b.sm (86,53 KiB) scaricato 976 volta(e).
kimkim 14/12/2025 10:31:17
#3 Pubblicato: 14/12/2025 10:35:04
kimkim
kimkim
I'm so appreciative of you.
When I draw SDF, BMD,' roots' function is more efficient than 'Solve' function as you wrote!!
Thank you.
#4 Pubblicato: 17/12/2025 22:39:59
Gruppo: Moderator
beam.sm (11,75 KiB) scaricato 943 volta(e).
ioan92 18/12/2025 06:21:56, sergio 18/12/2025 11:04:41, kimkim 18/12/2025 20:44:40
