is this solution correct?
is this solution correct? - Messaggi
#1 Pubblicato: 08/06/2023 21:04:50
soomoon
soomoon
1 apprezzamenti in 42 post.
question_230609.sm (3,75 KiB) scaricato 1370 volta(e).
#2 Pubblicato: 08/06/2023 23:35:04
Obviously not, but the bug isn't that obvious: just avoid to use that 'phi' (j Ctrl-G):
churichuro 09/06/2023 15:32:00
#3 Pubblicato: 09/06/2023 08:08:11
Is this solution correct ?
As given, your function is plain/native. Nothing else applies.
#4 Pubblicato: 09/06/2023 08:52:23
Gruppo: Moderator
Is it only valid for Windows?
Linux mono doesn't have this problem.
#5 Pubblicato: 09/06/2023 09:07:42
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Yes, these are different letters:
cos(ϕ) and cos(φ)
maple() works with φ
This was done to unambiguously convert variables into Greek letters:
maple() function uses implicit encoding of Greek letters:
#6 Pubblicato: 09/06/2023 11:58:48
I think the result soomoon expects is this, but it requires a newer version of maple:
#7 Pubblicato: 12/06/2023 01:58:17
soomoon
soomoon
where can i get a new version of maple ?
#8 Pubblicato: 12/06/2023 11:12:20
Inside SMath, you can't. This is a workaround, valid for real values
#9 Pubblicato: 12/06/2023 11:29:29
Gruppo: Moderator
Just in case that Maxima is an option. Unfortunately, Maxima requires the user to try specialized simplification functions and doesn't provide a powerful generic simplify.
trigsim.sm (2,43 KiB) scaricato 1373 volta(e).
