Rom2Arab
Rom2Arab - Arab2Rom - Messaggi
#1 Pubblicato: 18/10/2023 22:06:10
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
Why doesn't the cycle end?
See please the attachRome-Arab.sm (40,3 KiB) scaricato 1527 volta(e).
#2 Pubblicato: 19/10/2023 00:53:00
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
Really it's a very strange bahavior (a bug ?), because the value of variable n is cleared when function returns from Arab2Rom()
So, a solution is to use functions fwrite() and rfile() to save the value of n on a file as a memory:
See the atachment with the solution: Rome-Arab SOLVED.sm (41,21 KiB) scaricato 1532 volta(e).
best,
Oscar
Valery Ochkov 19/10/2023 01:08:00
#3 Pubblicato: 19/10/2023 01:30:20
Hi. In Arab2Rom(n) you modify n.
That's not good practice. This is a workaround for such cases.
Valery Ochkov 19/10/2023 01:46:00, Oscar Campo 19/10/2023 01:46:00
#4 Pubblicato: 19/10/2023 01:42:23
Valery Ochkov
Valery Ochkov
Thanks!
But this have an error too!
Rom2Arab.sm (293,29 KiB) scaricato 1514 volta(e).
#5 Pubblicato: 19/10/2023 01:52:56
Thanks!
That's another function, not similar with the others above. Here the problem is the origin in Mathcad for strings. Try to set ORIGIN = 1 in Mathcad and rewrite the code.
#6 Pubblicato: 19/10/2023 02:13:24
Valery Ochkov
Valery Ochkov
Thanks!
#7 Pubblicato: 19/10/2023 02:43:57
This is one way.
Valery Ochkov 19/10/2023 02:49:00
#8 Pubblicato: 19/10/2023 02:49:12
Valery Ochkov
Valery Ochkov
This is one way.
Thanks,
send please the sm-file!
#9 Pubblicato: 23/10/2023 00:30:24
Valery Ochkov
Valery Ochkov
My salary in 1980
ATM-SU.sm (6,29 KiB) scaricato 1524 volta(e).
#10 Pubblicato: 23/10/2023 01:34:42
Gruppo: Moderator
If I remember correctly, 1988 a bottle of vodka (0.5l) was 3 rubles (if you got it at all, it was the time of prohibition - сухой закон). Therefore the 3-ruble-notes.
Valery Ochkov 23/10/2023 02:31:00
#11 Pubblicato: 23/10/2023 02:24:31
Valery Ochkov
Valery Ochkov
2 рубля 87 копеек = 2.75 vodka + 0.12 bottle.
Three constants of soviet students 3.14, 2.87, 2.72
#12 Pubblicato: 28/10/2023 16:11:54
Valery Ochkov
Valery Ochkov
There are also zeros in Roman numerals. See my photo from Greenwich.
And four is written this way IIII and not that way IV because there are only 12 and not 13 digits.
