1 pagine (6 elementi)
question of roots - Messaggi
WroteHi. Because that's how what might be called "scalar expansion" for sys() works. Perhaps the result you are looking for is this using vectorize()
Thanks!
How it is better to set then an array of the data? Need to get a solution for some data (for example: values a 4, 5, 6, 7...)
Matrix didn't work either.
WroteHow it is better to set then an array of the data?
Hi. Supposedly, vectorize operates only on matrices.
WroteNeed to get a solution for some data (for example: values a 4, 5, 6, 7...) Matrix didn't work either.
It should have worked. Do you have an example of how it didn't work?
WroteHow it is better to set then an array of the data? Need to get a solution for some data (for example: values a 4, 5, 6, 7...)
Visit the Samples ... find zillions of examples.
