1 pagine (3 elementi)
Steam IF97 Implementaation - Messaggi
Many functions for water and steam properties are exposed. Library is unit-aware and outputs in standard SI units.
OS agnostic
Archive contains .zip plugin, .sm artifact, detailed documentation and source files
The problem I am facing is with few functions which work in my Linux but do not work in Windows. Perhaps someone can sort it out
IF97_Steam.7z (118,9 KiB) scaricato 71 volta(e).
OS agnostic
Modificato 17/10/2026 04:55:17
Learned something new
• Replaced all calls to System.String.Trim() in IF97Wrapper.cs:1024-1034 and Unit.cs:112 with the index-based scanner StripQuotes(string s).
• Binary verification confirmed 0 instructions and 0 metadata tokens reference Trim in IF97Wrapper.dll.
Should resolve previous errors on windows
IF97_Steam.7z (119,91 KiB) scaricato 68 volta(e).
francesco rapuano 17/10/2026 08:26:01
Completely updated OS agnostic plugin
Check /dist/*.zip for ready to use plugin
Code is hosted at github https://github.com/defencedog/smath-devel/tree/main/plugin/IF97_src_win
PDF: https://github.com/defencedog/smath-devel/blob/main/plugin/IF97_src_win/examples/if97_steam_tables.pdf
