1 pagine (17 elementi)
The value went beyond the maximum allowed positive number - the value went beyond the maximum allowed positive number, error in the solve function - Messaggi
Who has faced such a problem, how can it be solved?
Project from below
Poverochnyjj raschjot ehzhektora.sm (84,1 KiB) scaricato 1183 volta(e).
Project from below
WroteWho has faced such a problem, how can it be solved?
"result above max ..." has no pertinent meaning in your project.
If you attempt "roots" on the numerator only ... "Units don't match"
No need to go further ... zap the units in the project.
WroteWroteWho has faced such a problem, how can it be solved?
I made a mistake, there should be a solve function, in this place the same error
Joki,
Martin could have drawn the two curves and graphically estimated the two solutions
WroteMartin could have drawn the two curves and graphically estimated the two solutions
The solution must be automatic, plotting make and evaluating it is not appropriate
Common from ill posed construction.
Consider yellow up until you can plot that system(x,y):= ....
from there it should be solvable.
Poverochnyjj raschjot ehzhektora [zap Units, define the Undefined ...].sm (94,03 KiB) scaricato 1010 volta(e).
WroteWroteMartin could have drawn the two curves and graphically estimated the two solutions
Go on dreaming. If you are in non-linear systems and you can't find a symbolic solution (Maxima's Solve() got stuck when I tried) then you need numerical procedures for solution. These always need an initial guess (Newton-Raphson) or a search region (bisection). The various procedures just differ in how efficient or how robust they are. Some of them may have quite impressive radii of convergence for particular systems but none has infinite radius for all systems.
Furthermore, there remains the problem of uniqueness of a solution. The only solvers in SMath capable of providing multiple solutions are the
- solve() finds all solutions of a single equation within a given range
- Solve() from the Maxima plugin, which finds symbolic solutions.
Blatt21.sm (5,23 KiB) scaricato 1199 volta(e).
WroteFurthermore, there remains the problem of uniqueness of a solution. The only solvers in SMath capable of providing multiple solutions are the
Quite right and not enough wrt complex roots.
Cubic solver Exercise.sm (38,97 KiB) scaricato 1175 volta(e).
To OP's original question. I did get the same/similar error message on linear interpolation. One of the 5 required values had wrong value. After correcting no issues.
.WroteTo OP's original question. I did get the same/similar error message on linear interpolation. One of the 5 required values had wrong value. After correcting no issues.
What linear interpolation is doing here ?
If that document makes sense, return with comments.
Poverochnyjj raschjot ehzhektora [solve].sm (95,19 KiB) scaricato 1032 volta(e).
WroteWhat linear interpolation is doing here ?
I imagine you mean the very last part of the document.
The system looks ill posed, visit Solve Lecture last 3 days.
Poverochnyjj raschjot ehzhektora [solve, spline].sm (104 KiB) scaricato 1062 volta(e).
... maybe we can leave it as such ... cleanup ?
Poverochnyjj raschjot ehzhektora [solve, spline].sm (110,44 KiB) scaricato 1017 volta(e).
Inst_Isentropic Discharge.sm (173,76 KiB) scaricato 1157 volta(e).
![2020-02-13 11_38_00-SMath Studio 0.99.7251 - [Poverochnyjj%20raschjot%20ehzhektora.sm_].png](/it-IT/files/Download/qgUAWZ/2020-02-13-11_38_00-SMath-Studio-0.99.7251---[Poverochnyjj%20raschjot%20ehzhektora.sm_].png)
